MAXIM caliper on ebay
Discussion in 'For Sale, Trade/Swap, Wanted' started by BlackRig, Sep 12, 2007.
  1. BlackRig
    BlackRig Member
    Olmsted Falls (Cleveland), Ohio
    I just listed this if anyone needs one.
    1981 CALIPER
    Cool. Thanks guys.
  2. GCNTSi
    GCNTSi New Member
    Tallahassee, FL
    So anyone know if this will also work on a '80 650 Maxim?
    I would think it probably does but would like to know for sure before buying it. Thanks, Garrett.
  3. chacal
    NOPE! 650 Maxim's and 650 Midnight Maxim's used a caliper all their own!
    But, you're in luck!---I have a very nice used 650 Maxim caliper, already rebuilt with new seals, honed the bore, etc. Complete with shims, pad retaining pin. an almost-new set of pads (400 miles on them), the mounting bolt/hardware, bleeder screw and cap, etc.---I ended up swapping my single disc brake system to a dual disc system and this is one of the leftover parts (that's why it's already rebuilt). BTW, make SURE you keep that pivot bolt & sleeve WELL LUBED or you'll have all sorts of problems with the brake working properly and/or squeeling!
    If you want it to be picture-perfect, you'll have to re-paint it.
    $ 59.00 plus shipping!
    If you just want to rebuild your original caliper, here you go:
    HCP749 OEM factory Brake Caliper Rebuild Kit, for all XJ650 Maxim and Midnight Maxim models, and XJ1100 models rear caliper. One kit does one caliper. Note that the fluid seal circular retaining circlip is included. Each:
    $ 39.00
    HCP1698 aftermarket Brake Caliper Rebuild Kit, for all XJ650 Maxim and Midnight Maxim models, and XJ1100 models rear caliper. One kit does one caliper. Note that the fluid seal circular retaining spring is not included and must be re-used from your original system. Each:
    $ 15.00
    HCP759 OEM factory front disc brake Pad Set, enough to do one front caliper. Fits all XJ650 Maxim and 650 Midnight Maxim models with front disc brakes. Each set:
    $ 33.00
    HCP1706 Aftermarket EBC brand organic front disc brake Pad Set, enough to do one front caliper. Fits all XJ650 Maxim and 650 Midnight Maxim models with front disc brakes. Each set:
    $ 32.00
    I also have a nice, freshly rebuilt 650 Maxim Complete Master Cylinder available if you are interested...new cover, diaphram, seals, complete with the brake switch and lead wire (no brake lever). This m/c has a new, clear glass fluid sight window already installed in it.
