Hitachi Fuel Bowl Cross-Sectional View
Discussion in 'Test Zone' started by Gamuru, Apr 4, 2008.
  1. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I'm working on a informational post but wanted to get some feedback on a picture I drew with AutoCAD. This should be a pretty accurate cross-sectional view of a Hitachi Fuel Bowl that has been sliced down the center of the Enrichment Circuit Well. Here's what I need from the experts (you know who you are):
    • Proper Terminology: Am I calling things by their correct names?
    • Image Accuracy: Does my picture depict correctly what it found in the well?
    • Image Clarity: Does the picture portray the fuel bowl clearly, or is it confusing to look at?
    Feel free to add anything else that you feel pertinent/relevant to the proper cleaning of the Enrichment Circuit Well.
    Thanks,
  2. Gamuru
    Gamuru Guest
    Granite Falls, WA
    <BUMP>
  3. MiCarl
    Good drawing.
    I've already stolen it.
    Thanks.
  4. chacal
    Suggestions:
    a) I would define and label the STARTER JET in the bottom of the well.
    b) If you could slug in a carb drain screw, that would be great too.
    c) Except for the carb bowl drain "nipple", this cross view is the pretty much the same for Mikunu bowls, too.
    d) You may want to have a top view also, so they can "see" it as they see the bowl in reality, too.
    e) Label the "well" that you are trying to describe; a newbie may not be able to tell what/where the "well" is.
    f) I suppose all of this is in anticipation of running the new Gamuru Ad Campaign that extols the virtue and patriotic necessity of CLEANING THE STARTER JET IN EVERY SINGLE CARB BOWL IN EXISTENCE, and as such, I would also link to (or create your very own) picture to go along with it, like the one here within the FinnoAngela post of 4:23pm:
    http://www.xjbikes.com/Forums/viewtopic ... rt=15.html
    Other than those, very good and much appreciated!!
  5. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Len, you crack me up! :lol:
    Done.
    Decided to skip it for two reasons. It's not technically visible from the side and I'm not addressing the drain screws. (I'll make you a special one, though :wink: )
    I didn't know that. Thanks.
    I've got one in mind.
    Done, too.
    Seriously, get out of my head. You're really starting to freak me out! :?
    You're welcome.
    Here's the new and improved version:
