air jets with no cover
Discussion in 'XJ Technical Chat' started by Door dude, Feb 8, 2017.
  1. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Im doing a carb rebuild and i took the top plate off and diaphragm out and saw the 2 air jets. Looking at the Haynes manual it shows a cover plate over the two jets mine does'not have that plate. Do i need the plates ? I know back in 1982 my 650 had the plates.
    cover is no longer used even though the screw hole is still there yamaha did away with it
    make sure you put the jets back in the correct place haynes manual is incoerrect
  3. XJ550H
    correct location
    Thomer69 likes this.
  4. k-moe
  5. k-moe
  6. Door dude
    Im sure i got them right looking at your pic and the one's i took. Thanks for the help guy's.
