She messed up again boys....
Discussion in 'XJ Technical Chat' started by Xj Bobber, Aug 12, 2015.
  1. Xj Bobber
    Xj Bobber Member
    ohio
    So my bike quit on me again. i checked my battery and i even hooked cables from my blazer to my bike and still no start. What else am I missing that i'm not realizing??
  2. Xj Bobber
    Xj Bobber Member
    ohio
    i have and 82 xj550 for the new people. Its a no spark issue.
  3. Ribo
    Ribo Prefectionist
    So it's turning over but not firing right? Check plugs and leads back from the plugs and test voltage across your solenoids would be my first step if you're sure the battery is kicking out enough.
  4. Xj Bobber
    Xj Bobber Member
    ohio
    ive checked coils caps lines all the wiring fuses everything is good. I'm getting a new ignition switch today because my old one seems pretty wore out.
  5. Ribo
    Ribo Prefectionist
    Compression?
  6. XJ550H
    did you check the pick up coil resistance?
  7. XJ550H
    is your tail light coming on when you turn the key? are you getting voltage into the fuses?
    http://frankjohansson.com/stuff/xj550/XJ550ElectricalDiagram.html
    could you answer the questions asked?
    is it turning over?
  8. Xj Bobber
    Xj Bobber Member
    ohio
    its good and yes all the lights including the tail light comes on
  9. XJ550H
    whats the ohms reading for your pick up coils, you test that from the left plug in the tci box.
    pick ups trigger the spark
  10. XJ550H
    heres the way to test it from fsm it forgets to tell you to remove plug caps in the test. or include cap resistance in the reading if you do not remove them
  11. XJ550H
    that would be orange to black wire
    gray to black wire on the left tci plug.
    when you know whats good it makes it easier to look for what is bad
  12. Xj Bobber
    Xj Bobber Member
    ohio
    If i remember correctly it was around 2 to 2.5
  13. XJ550H
    if around 2.5 is your ignition coil primary it is good and there are 2 coils to be checked if it is 2 ohms that is low and out of spec. that resistance can be checked at the RIGHT connector of tci or at 2 connectors at coils under gas tank.
    the wiring can be seen on the lower right of the wiring diagram link i posted
    what is the resistance of the pickup coils?
    as i said it can be checked from the left tci connector
    gray to black wire on the left tci plug. should be 650 ohms
    pick up coils are in the left side crank cover, if your pick ups are bad no spark even if the coils with the spark plug wires are good.
  14. XJ550H
    if your battery is not fully charged and goes less that 10 volts when starting you will not get any spark. that is covered on the flow chart i posted.
    test the voltages at the fuses both sides , do you have glass fuses or a new fuse block with plug in fuses old style fuses fail at the connectors so you will also want to look for 12 volts at the tci connector right side should be a red wire with a white stripe.
  15. Ribo
    Ribo Prefectionist
    Your Avatar dog makes me read anything you say with fear. ;)
    Stumplifter likes this.
  16. XJ550H
    he scares the hell out of me too all 22 pounds of him. does not like his photo taken
  17. Ribo
    Ribo Prefectionist
    May I suggest a picture of a fluffy bunny wabbit ;)
  18. XJ550H
    would this be better? He helps supervise my crew at work
    Ribo likes this.
  19. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Beekman likes this.
