Xj650 neutral switch location
Discussion in 'XJ Technical Chat' started by jamiedransfield, Nov 5, 2015.
  1. jamiedransfield
    jamiedransfield Member
    The world
    Hi guys, can anyone tell me where to find the neutral switch? The neutral lught stays on in gear so need to remove and check it.
  2. wingnut325
    wingnut325 Member
    Havelock North Carolina
    Under the lower left hand side Close to the shift leaver
  3. jamiedransfield
    The world
    Ok. Is it under the cover or...?
    Anyone got a picture by chance?
    It's in the oil pan. THe neutral light staying on might mean the swith is stuck, or it mibght mean that the switch has bee bypassed.
    Look for a sky-blue wire running along the lower left frame tube (round about the shift lever region). That is the neutral switch lead (the switch grounds to the case when in neural). That wire runs to the switch. If you have a Maxim you'll be able to see it. If you own a Seca the exhaust collector pretty well blocks the view (and access).
    jamiedransfield likes this.
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    In the middle of pic, has the wire held on with a Phillips screw.
  6. chacal
    Nice picture. Clean engine. Take note that if the engine is still in the bike and/or the exhaust system is still on, it will be hard to see and even harder to get to........
  7. jamiedransfield
    The world
    Thanks guys. That pic is awesome!!!
    Ive a seca so looks like im in for some more fun/pain playing with this.
    First up need to get a battery charger, then ill atrack this sucker and then restart banging my head against the bloody carbs.
    Thanks so much guys!
  8. Chuck007
    Chuck007 New Member
    Sierra Madre, CA
    Does anyone know:
    IF the neutral switch is bad....will this prevent the bike from sparking at all? The wire going to the starter circuit cut off relay on my bike is a dark royal blue, not a sky blue like it's supposed to be...WTF.
    Anyway...would a bad switch prevent spark?
  9. k-moe
    Please start a thread for your bike.
  10. kosel
    MInneapolis, MN
    Here's 2 pics I took when I finally found the neutral switch on my 650 Seca.
    One side view, one from underneath.
