fuse ratings 750 seca
Discussion in 'XJ Technical Chat' started by Ltdave, Apr 7, 2008.
  1. Ltdave
    Ltdave Member
    okay, ive been thru the owners manual and the service manual for the last 2 hours. i can NOT find the correct fuse values for this bike...
    i pulled the glass types out of the fuse block and i got one fuse that came apart in my hands (headlight. maybe thats whats triggering the headlight warning) and the following values:
    Main 20A
    Headlight 10A
    Signals 30A
    Indicators 30A
    now im thinking they had the wrong fuses in the signal and indicator spots correct? the reason i put them in this order is because thats how i pulled them starting with the main conductor (red on the line side with the other 3 brown)...
    did they just have them in the wrong order? i dont recall on my 550 what the values were but im going to be making up my wiring lables at work tomorrow and i want them to be correct
    d
  2. chacal
    Fuses by model:
    Weather-proof Fuseboxes, Fuseholders, and Fuses:
    COMMENTS: your stock fusebox was marginal, at best, and that was 20+ years ago. Replacing it with a modern style fuse panel or in-line fuse holders such as the styles listed below will prevent frustrating, expensive, and potentially dangerous electrical system problems for years to come.
    The following models used a fusebox utilizing four "glass tube" AGC fuses with one 20A main fuse, and three 10A fuses for the ignition, turn signal, and headlight circuits: all XJ550 models, all XJ650 models, 1983 XJ750 Maxim and XJ750 Midnight Maxim models, and the main fusebox on XJ1100 models.
    These models used a fusebox utilizing four "glass tube" AGC fuses that contained one 30A main fuse, and three 10A fuses for the ignition, turn signal, and headlight circuits: 1982 XJ750 Maxim model, all XJ750 Seca models, and the XJ900RK.
    In addition, the following models used a separate single "glass tube" 5A AGC fuse, within its own small in-line holder, for the computerized gauge cluster: all XJ650 Turbo models, 1982 XJ750 Maxim, and all XJ750 Seca models.
    XJ700 models used two separate fuse panels: one that contained the four seondary circuits, including two 10A fuses, and two 15A fuses, which is located within the instrument warning lights panel; and the 30A main circuit fuse panel was located under the seat. These bikes used the later push-in style ATC fuses in the dash fuse panel from the factory; the 30A main circuit fuses were still the older "glass tube" AGC style fuses.
    XJ1100 models also used two separate fuse panels: one that contained the four seondary circuits, including one 20A fuse, and three 10A fuses, and which is located behind the right side panel; the 30A main circuit fuse panel was located under the seat.
    q) Replacement FUSEBOX, enclosed, weatherproof 6-circuit ATC (mini push-in blade style) fusebox....the one that everyone recommends using. Includes 6 ATC standard fuses, 2 x 20A or 2 x 30A (depending on your model), and 4 x 10A. Two more circuits than a stock fusebox allows you to add extra circuits for heated grips, cigarette lighter, headlight relays, etc. Size: 4" long x 1-1/8" wide (not including spade terminals) x 1-1/2" tall (including the clear, see-through cover). Note that this is a "side-terminal" design...the male wire terminal spades point outwards (away) from the sides of the fusebox.
    HCP378BC Replacement FUSEBOX, 6-circuit design, comes with a full set of standard style ATC push-in style fuses (4 x 10A, and 2 x 20A), for all XJ550, all XJ650, 1983 XJ750 Maxim and XJ750 Midnight Maxim, and XJ1100 models.
    $ 13.00
    HCP378LF Replacement FUSEBOX, 6-circuit with a full set of glow-when-blown indicator style ATC push-in style fuses (4 x 10A, and 2 x 20A), XJ550, all XJ650, 1983 XJ750 Maxim and XJ750 Midnight Maxim, and XJ1100 models.
    $ 16.00
    HCP7153BC Replacement FUSEBOX, 6-circuit design, comes with a full set of standard style ATC push-in style fuses (4 x 10A, and 2 x 30A), for all XJ750 Seca, 1982 XJ750 Maxim, and XJ900RK models.
    $ 13.00
    HCP7153LF Replacement FUSEBOX, 6-circuit with a full set of glow-when-blown indicator style ATC push-in style fuses (4 x 10A, and 2 x 30A), for all XJ750 Seca, 1982 XJ750 Maxim, and XJ900RK models.
    $ 16.00
  3. Robert
    Geeze, 2 cent question, $2 answer! And a good one at that! Includes requested info and suggested fix, what isn't to like!
  4. Dodger62
    Dodger62 Member
    Renton WA
    Actually. The main fuse is 30A, and the other 3 fuses are 10A fuses. Running a higher rates fuse in a 10A circuite could mask an electrical short and could result in a burnt wire and possibly burning out the wiring harness.
    Your warning light is more then likely being triggered by a gounding issue or high resistance in the wiring from corrosion. Use an ohm meter and check the grounding circuit to the headlamp and accessory light. The lower the resistance, the better.
  5. Robert
    Admittedly buried in the details but it's all there Dodger. However, you are correct in mentioning the dangers of running to high a rating on any given circuit. Glad you pointed that out. Lt, did you get everything straightened out?
  6. chacal
    And for what it's worth, a 30A fuse is WA-A-A-A-YYYY too large a fuse for a circuit that's using such small wires (14-gauge, I believe). A 30A circuit should be using around 8- or 10-gauge wire..........
