HELP ASAP ghost cranking
Discussion in 'XJ Technical Chat' started by Wannaride, Aug 25, 2008.
  1. Wannaride
    Wannaride Member
    Sydenham, Ontario
    Here's a good one:
    fully charged & new battery
    clean contacts for start button, solenoid
    "new" reconditioned starter
    cleaned carbs (done by friend...don't know exactly HOW clean)
    Key in/run...try try no turnover (repeat three times, wait in between so you don't flood it)
    Key in/run...try pthhhh (which usually meant it was about ready to turnover)
    nothin.
    wait, try again. Starter button depressed, try try...starter button let go...it's still trying. run button clicked off...it's still trying.
    key out...it's still trying.
    negative lead off of battery....stopped
    Now I'm afraid of electrocuting myself and of course...
    ruining my new battery.
    What can I touch?
    What should I do next?
    thanks, all
  2. Artjim
    Artjim Member
    Arkansas
    First, you need an old priest, and a young priest...
  3. wizard
    Key in/run...try try no turnover (repeat three times, wait in between so you don't flood it) (quote)
    it wont flood if it isn't turning over.
    12 volts won't electricute you. can burn if shorted out.
  4. Polock
    your solenoid is stuck closed, give it a good smack with a screwdriver handle
    this might free it up, start looking for another one
    the way it is now the two big terminals are connected, they shouldn't be
  5. Wannaride
    Wannaride Member
    Sydenham, Ontario
    tks, guys.
    Jim. you're funny! You're the one who favors JPII in the electrical tutorial photos, or am I thinking of some other R.C.?
    fuh duh...ok... so is the solenoid likely the rest of my starting problem with the "pthhhhh" sound creeping in there or might I have other issues besides the fact that I'm still so new at this? tks
  6. Polock
    i think what we need to do here is define the term "pthhhhh"
  7. Wannaride
    Wannaride Member
    Sydenham, Ontario
    oh yah.
    right
    So the the bike starts to make its noise (the noise immediately prior to the engine turning over) Then I get this noise (or I don't get this noise, depending on the moment in time and space) that sounds like a pulsing raspberry sound (the kind you can make with your tongue stuck out and lots of air coming from your gut..that's what I spelled "pthhhhh" After pulsing that sound a couple of times, it will usually turn over. This time, the solenoid got stuck.
    thanks
    Really tough to describe sounds..I need to get a recording device;-)
  8. Polock
    ok, well now that the hunt is on for a solenoid, a general rule of motorcycle repair is any noise that starts with "pth", or "pft" gets smacked with a screwdriver
    "eer" , "bzz" get oiled and "euu", "krr" need adjustments :)
    and if you smell something burning while on your bike, it's not you, unless your at a red light
  9. Wannaride
    Wannaride Member
    Sydenham, Ontario
    ROFLMAO
    You guys are hilarious!
    pfthhhhh
    (so green it hurts)
  10. wizard
    what's this guy got, a problem with his bike, or a speech impediment?
  11. schmuckaholic
    California
    I don't know. Polock wants to whack Daffy Duck with a screwdriver??
  12. bigfitz52
    HEY!!!!
  13. Gamuru
    Gamuru Guest
    Granite Falls, WA
    We are to laugh!
  14. bill
    bill Active Member
    Raleigh, NC
    Now we are way off topic but LMAO - very funny stuff...
