CARB REMOVAL 82 XJ650LJ
Discussion in 'XJ Technical Chat' started by 209SECA, Sep 6, 2008.
  1. 209SECA
    209SECA Member
    MANTECA CA
    I am going to take the carbs off my bike today after work. Should I take them off be removing the the alan heads on the rubber boot from the carbs to the head or should i loosen up the clamps on the boot and leave the boot on the head? Can I leave the aluminum intake (goes from air filter to carbs and has turbo inlet) on or should I remove that first?
  2. kordasn
    kordasn Member
    Toronto, Ontario, Canada
  3. 209SECA
    209SECA Member
    MANTECA CA
    Right on. Thank you Kordasn. I search the forums but some how I did not see that thread. Much appriceated.
