Are all xj750's created equal?
Discussion in 'XJ Technical Chat' started by krayzeesmoke, Aug 18, 2008.
  1. krayzeesmoke
    krayzeesmoke Member
    Lexington, KY
    Will the carbs off of a 1983 XJ750 Midnight Maxim fit a 1982 XJ750 Seca? Is there somewhere that has a XJ parts crossover list? :?:
  2. chacal
    Yes, they will!
  3. krayzeesmoke
    krayzeesmoke Member
    Lexington, KY
    So am I correct in saying that all XJ750's are compatible (at least the engine) between the years of 1981-1983
  4. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    120 main jets and 40 pilots
    a y-13 needle, i think.
  5. bigfitz52
    The best way to check, part by part, is to use an online microfiche, and compare part numbers between the "R" and the other XJ750 models in that year (or years.) If it's the same, it will have the same part number (most of the time.)
  6. TIMEtoRIDE
    Maxim's have slightly milder cams and a tad taller overall gearing.
    I think a Maxim motor in a Seca would be a good swap for better fuel economy, or a Seca rear rim installed on a Maxim.
  7. switch263
    switch263 Member
    Austin, TX
    While I agree with this, i have to say... I'll take the bad gas mileage on a bike that'll pop the nose :D Now if only I can figure out how to consistantly clutch it up....
  8. krayzeesmoke
    krayzeesmoke Member
    Lexington, KY
    What kind of gas milage are you getting on your bike? (should this be another thread?)
  9. NursePadawan
    NursePadawan Member
    Lansing, MI
    I never fill my bike all the way up (skeered of splashing gas on my tank), so I'm not sure how to get an accurate calculation. Would keeping tabs on the GPM help in recognizing a problem? Do you factor in the engine warm up time (choke on) in your calculation?
    I've started a habit. I put the bike in Neutral, start it with the choke on, perform a walk around looking for dripping fluid, listen to the engine, check the exhaust, the lights, turn signals, and tires. Put my gear on, turn off the choke, then get on the bike and go.
  10. grimreaper169
    grimreaper169 Member
    Mims,Fl.
    So what you are saying is if I put a Seca final drive on my Maxim I will get more top end. Will it be noticeable?
  11. 85MaximXX
    85MaximXX Member
    S.W. michigan
    nope grim I have checked same p/n between the two bikes
  12. stereomind
    stereomind Active Member
    Tulsa, OK
    The Seca's rear wheel is a 120/90/18. Maxim runs a 130/90/16. That's about a 5% difference, which gives the Seca a bit more top end. On the other hand, the 120/90/18 tire is almost an inch narrower, so you don't have quite as much rubber on the ground.
  13. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I swap out a Maxim rear wheel for the Seca wheel when I go for short rides around here. The Seca wheel is for longer trips and better top end (less rpm) and better fuel mileage. The 650 Maxim wheel fits perfect onto a 750 Seca.
  14. Ease
    Ease Member
    NL, Canada
    You can put a 130 width tire on the Seca.
    I have a 130 dunlop GT501 on mine.
  15. stereomind
    Tulsa, OK
    Ease,
    You got a 130 on a 18 in. rim? no clearance issues with the driveshaft? 8O
  16. PainterD
    Yup, it just makes it past the differential housing with a litttle push. Plenty of room next to the drive shaft too.
  17. stereomind
    Tulsa, OK
    cool! then I can go back to the Seca rim... I just always thought the 18 in. rim was too narrow for a 130.
  18. RickCoMatic
    I think if you dig deep enough into the Technical Data you'll find that the Seca is a faster bike.
    Although I wouldn't swear to it under Oath ... I think the Seca's have a little bit hotter Cam.
    In lane one ... the 750 Max
    In lane two ... the 750 Seca.
    White, white
    Red
    Red
    Yellow
    Green
    Looks like the Seca edged-out the Max after the quarter-mile run.
    Gotta be a reason.
    Must be those Cams.
  19. Ease
    Ease Member
    NL, Canada
    Aw, damn... Sorry, seems I was wrong... Had to check b/c I could have sowrn it was a 130.
    It's a 120...
    Hope noone ran out and bought a 130 on my advice. :oops:
    Anyway there is a decent amount of space between the shaft now, but looks like a 130 wouldn't fit without some modification.
  20. bigfitz52
    umm...guys...RIMS come in different widths too, and limit how wide a tire can be fitted. Your rim has its width number (ie; 2.15) cast onto it.
  21. stereomind
    Tulsa, OK
    I noticed that the 16" rim is about an inch wider than the 18" Seca variant... I also found out today that some Cheng Shin 120/90/18 tires are actually almost as wide as 130's. Apparently following standards is optional in Taiwan...
