25 year old nuts n bolts
Discussion in 'XJ Technical Chat' started by rdbhere2, Sep 22, 2008.
  1. rdbhere2
    rdbhere2 Member
    Word to the wise, nuts and bolts on these bikes will break before they loosen. Ask me how i know these things.
  2. nsosh5
    nsosh5 Member
    oklahoma
    Aero Kroil works wonders
  3. stormothecentury
    stormothecentury Member
    Rochester, NY
    How do you know these things?
    (Hey, I'm nothing if not agreeable, sometimes.)
  4. dqnjuan
    dqnjuan Member
    bmore, md
    yeah one of the bolts where my exhuast connects to the engine snapped, and i was just snugging them up not even loosening.
  5. bill
    bill Active Member
    Raleigh, NC
    I think we are all very familiar with this one - I've had my share...
  6. RickCoMatic
    It's a crying shame that during manufacturing Yamaha cut-corners and used some pretty cheap hardware Cap Screws (Manifolds) and Studs (Exhaust Collars) on critical hardware of the Cylinder Head.
    The number of cases where a Manifold Cap Screw has seized and broken on an Owner or Technician attempting to remove Manifolds is quite large.
    The same can be said for the Exhaust Side Studs when the Flange Donuts require replacement.
    If you are fortunate enough to have removed your Manifold Fasteners without a failure --> discard them and replace them with a HARDENED Fastener or Stainless Steel after applying an AntiSeize Compound to the Threads in the Head.
    Same for the Studs on the Exhaust Manifold side.
  7. grimreaper169
    grimreaper169 Member
    Mims,Fl.
    If I get it off I replace it with stinless allen head every time. Untial I get them all changed out tho I need all tools in the box to work on it.
  8. ricklees
    ricklees Member
    St. Louis, Missouri
    I'm doing the same Grim'
    I left it set, Thats my fault
    Yamaha built it, surely I can fix it? LOL
  9. brent_bastien
    brent_bastien Member
    Commerce mi
    this is a lesson i have learned over the years
    if it doesnt come off easy apply lubricant or heat or both (especially stuck lug nuts on your truck or car)
    when you get it out replace it with new in stainless with anti seize
    (every screw on my carbs are now stainless)
    if you round a head on say an oil pan bolt or a brake bleeder dont use an easy out its to much work get yourself a small pipe wrench they will grab on anything then replace the mangled screw (dont forget the heat)
