OIL IN THE AIR FILTER?!?!?
Discussion in 'XJ Technical Chat' started by GreaseMonkey, Sep 24, 2008.
  1. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    ok so there is oil dripping out of my airbox. I pull it open and there is oil all over my filter can anyone tell me why and how bad it is?
  2. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Is your Oil level over filled ?
    If so, does it smell like Gas ?
  3. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    might be over filled
  4. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    is that a huge deal?
    the oil came from my carb
  5. xyxj650
    xyxj650 Member
    Fergus Falls MN
    Sounds more like you may have a fuel leaking problem. These bikes have a tendancy to do this. First check your oil and see if it smells ike gas. If it does you NEED to change it before you ride your bike or else you may have some problems. If it is fuel that caused this you have either a stuck float or a bad fuel valve on you tank. Hope that I may have helped. Good luck!
  6. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    it was leakin like a son of a b
  7. Polock
    that's better than air in the oil filter :)
  8. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    nope doesnt smell like fuel... any other ideas anybody?
  9. Polock
    put it on the center stand and check the oil level, you want to be 3/4 of the way up the window
    you don't want to hear this, but it could be bad rings blowing into the bottom end
  10. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    oh man thats not good
    I know for a fact my oil is too high then becuase it covers the window
    but its never leaked like this before
  11. Polock
    drain some out, make a big mess then see what happens
    i'd spray that air filter with half a can of brake cleaner, let it dry and put it back
    the intake on the airbox is clear, right
  12. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    how do you mean clear?
  13. TheHound
    TheHound Active Member
    Scotia, NY
    I would have said it was coming from the breather, but you say it's coming from the carbs.
    Only one place it can be comeing from then.
  14. bigfitz52
    I think your oil was horribly overfilled and it pumped out the breather into the airbox. XYXJ650 is right, there is a tendency for these bikes to have a carb issue which fills the crankcase with gas. However, PEOPLE seem to fill the engine with too much oil with great frequency as well. FOOL PROOF OIL CHECKING procedure: Bike on sidestand, look at sight glass. You should see nothing. Stand bike up toward vertical (may require assistant.) As you stand the bike up, you will see the oil level rise in the sight glass. Correct level is between the upper mark and completely full, with just a "bubble" showing at the top (representing a SLIGHT overfill.) If there is oil showing in the sight glass with the bike on the SIDESTAND you have way too much oil in there.
  15. Robert
    And don't forget to change the air filter when you get the oil level ironed out. With oil wicked into it, it can't pull sufficient air and will run poorly.
  16. Fongdingo
    Fongdingo Member
    Charlottesville VA
    yup i had this problem too when i frist gt my bike, overfilled the oil and got it in the air filter, i drained then mesured out the specs for the oil and got a new air filter and did it the right way havent had any prob with it since. air filters are cheap
  17. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    Ya seemed to just be a level problem thanks for the help everyone.
  18. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    sure did freak me out though.
