cleaning the air filter
Discussion in 'XJ Technical Chat' started by GreaseMonkey, Sep 24, 2008.
  1. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    I have oil in my air filter anyone know how I can clean this bad boy or am I screwed...?
  2. RickCoMatic
    Spray it with Carb Cleaner from the Inside-out.
    Before you spray it ... it's dead.
    Spraying it will get the Oil out.
    Spraying it might ruin it ... but, it's already dead.
    If it don't come unglued and fall apart on you ... let it dry.
    Order a new Air Filter anyway!
    Use the one you clean until the new one get here!
  3. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    hey thanks a lot
  4. Robert
    I've used Castrol Super Clean to soak the element, then rinse the assembly from the inside out to flush the emulsified goo out. Then you need to let it dry a few days. I've recovered two airfilters using this method but it took multiple cycles of soaking and rinsing. For the effort, buying a new one is a time and money saver (just not as ecologically sound). Another safe solvent is K&N's filter cleaner. Won't harm anything.
  5. bigfitz52
    What Rick said...
  6. GreaseMonkey
    GreaseMonkey Member
    So-Cal
    Thanks everyone worked like charm
  7. DSwanson83
    DSwanson83 New Member
    Denver
    Do you air filtuer gurus recommend the eom paper filters? Or should I fork out the cash and get one of the $35 ones? I realize the pleated paper ones won't last as long and may have a tad more airflow restriction, but do you think the performance sacrifice is substantial enough to spend twice as much?
  8. XJDriver
    XJDriver Member
    Sacramento, CA
    Get a K&N one, then you'll never have to buy another one :)
  9. Robert
    What is your pleasure? Some aftermarket filters can be more restrictive than the stocker so buyer beware. Invest in only a known brand (K&N, Uni come to mind) to avoid this pitfall.
    There really isn't much to complain about concerning the stock filter, it just needs to be replaced when it gets dirty (not very environmentally minded).
  10. bill
    bill Active Member
    Raleigh, NC
    While we are no the subject the UNI site says you may need to rejet due to higher air flow.
    Anyone try one? is rejetting required?
  11. Danilo
    Danilo Member
    Vancouver canada
    yes Either K& N or Uni "should" require a rejet , Few do it though.
