Odd tire question
Discussion in 'Hangout Lounge' started by kd5uzz, Feb 5, 2009.
  1. kd5uzz
    kd5uzz Member
    Awhile back I posted a picture of an old Kawi dirt bike. I ended up trading it for a few sets of handlebars and a used tire. I just got home and while looking at the tire I notice that it says 'Front tire fitment'. It is a 130/90/16. Can I use it on the rear?
  2. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
  3. TIMEtoRIDE
    Supposedly, no. If you used it, you would need to run it backwards, but the threads have already taken a "set" (the theory goes), so it's bad to run it forwards, or backwards, or expect unusually fast wear.
    I got a new set of Avon tires with matching tread patterns, but my front had to be mounted "backwards" which looks a bit odd to me.
  4. MaximumX
    MaximumX Member
    Ottawa, Canada
    I would definitely avoid running a front tire on the rear. Not only are the tread patterns different, but front tires seem to have a rounder cross-section. At least that's been my experience.
    Best thing might to post it up for sale. Someone on here (maybe even me) might be interested, depending on brand, condition and cost.
  5. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Not to get off topic, but why, if you were to mount a front tire on the back would you mount it backwards?? I've never heard that before, and I'm just curious why.
  6. Polock
    calling Mr Fitz, one size fits all on some old British iron
  7. TwoWheelFiend
    TwoWheelFiend Member
    certain tires are designed for front and rear fitment, chen shing makes some i believe. I would not run it one the back if i were you. Just buy a new tire.
  8. MiCarl
    It has to do with the way the belts are laid up. The rear gets high torques in acceleration, front gets high torques braking.
    The rear tire that was on my 650 had two arrows on it, one for front mounting and one the opposite direction for rear.
  9. bigfitz52
    TRUE. My Norton has 4.10X19 Dunlop K81 TT100's front AND REAR. But ya know what? They have TWO arrows on them. One is for FRONT mounting rotation, one is for REAR mounting rotation and they point in different directions.
