Isn't winter over yet ? !!!
Discussion in 'Hangout Lounge' started by Teewinot, Jan 19, 2009.
  1. flash1259
    flash1259 Member
    W.R. Wisconsin
    At least we don't get hurricanes!
  2. ktcubed
    ktcubed Member
    St. Augustine, FL
    Did I mention that I got bit by a mosquito last night. First sign of spring in Florida. Think they were gone for about a week.
    By the way time, I think it 67.235% that are made up on the spot...
  3. protomillenium
    protomillenium Member
    New Buffalo, Michigan
    I've been working on my XJ550, and 750 Secas, and a GS550 in my garage. I have a forced air kerosene heater. It gets the place warm enough, but a heavy dew forms on the metal parts and engines. On the coldest days a frost will form on the engines! It's spoiling the polish job I did on the aluminum cases. I decided since, to clear coat the aluminum after polishing, hard enough to polish them once. I got 3 bikes running fair, but fine tuning will have to wait for clear roads. Even starting them is out until we get above freezing.
  4. Teewinot
    Teewinot New Member
    Trego, Wisconsin
    They predicted the temps would start to turn around and rebound into the single digits but I still woke up to -23 degrees F this morning.
    I don't dare sit on my bike and make "vroom vroom" noises. My wife would probably find me hours later, frozen to death in the saddle, with a smile on my face.
    By the way, I got a second opinion on the dog and it turns out the first vet got it wrong. Not a torn ACL. Just needs some rest and some time and he should be back in action.
  5. bill
    bill Active Member
    Raleigh, NC
    good news for the dog and your wallet. Glad it worked out
  6. bigfitz52
    This happens to me too, I keep a clean bath towel in the garage and just dab them off once the frost melts. If you used Mother's or the like as your final finish when you polished them, it shouldn't ruin anything; it contains a wax. Mine have "sweated" and been toweled off a few times with no detriment to the polished cases. The Norton was sprayed down with WD40 so that one's not even an issue.
  7. TIMEtoRIDE
    Alkasmeltzer- - - :p 8)
    I still have to run the beater Sea-Doo with fresh gas, and a 4 horse kicker :wink:
    As for hurricanes impacting Clermont, I'm 70 miles from either coast.
  8. flash1259
    flash1259 Member
    W.R. Wisconsin
    Thats ok timetoride . i see it this way
    In the summer I ride my bike, boat , in the winter my car or my snowmobile.
    You you have a summer most the year and will have to replace your tires more often than we in the northern states. LOL
  9. Big_Ross
    Big_Ross Member
    It was 93F here last night. That was our MINIMUM!
  10. Teewinot
    Teewinot New Member
    Trego, Wisconsin
    Spring is almost here at last. I can finally see the deer moving around outside again.
  11. bill
    bill Active Member
    Raleigh, NC
    Reached 50 here today I took the day off to do some maintenance an took and hour + ride - nice to get out and ride again. Unfortunately next week is cold and rainy.
  12. kd5uzz
    kd5uzz Member
    64 yesterday, the same today (friday), and almost the same tomorrow. Then it gets cold for a few days (20deg F), then back up to 70 (!) on Friday.
  13. protomillenium
    Feb-7th, New Buffalo, Michigan: 55º!
    I just got back from a 37mi Joy Ride! I think it's been since Thanksgiving that we had one day without SNOW!
    It was great! :D
  14. alkasmeltzer
    alkasmeltzer Member
    Lincoln, NE
    That Mother Nature is a true B***h. Been 20*F or below for three weeks. Tank the tank off for paint and dent repair and Boom, Thursday 63*, Fri 65*, today 60*. And I can't ride!!!!
    Anyone wanna bet it gets colder than a well digger's balls when I put it back on?
  15. Galamb
    Galamb Member
    Acton, Ontario
    Still in the garage. It will be nice for a couple of days and after that will be cold again. Not worth to put the battery and the seat back. Gas tank is full with stabilizer and the bike is oiled up from front to back. Let her hibernate another month or two. :)
  16. trekrider
    trekrider Member
    lancaster PA
    Yea, I was tempted to take my XJ out and start it, but I will let it go another month, it will get cold again, winter is still hanging on.
  17. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    60 mile trip today.
    59 degrees and sunny.
    Beautiful day to ride.
  18. trekrider
    trekrider Member
    lancaster PA
    Watch for cagers, they are not used to seeing motorcycles this time of year.
  19. bigfitz52
    It got to 53* here today, I was going to take the project bike for a ride BUT... The fuseholder for the "IGN" fuse mysteriously fell to bits. (I haven't retrofitted the fusebox yet, it was on the to-do list.) Did the Radio Shack repair, now if it gets warm again tomorrow...
  20. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Its supposed to be low 60s here today.
    Time to suit up.
  21. protomillenium
    You better be ready for Tuesday, it looks like a ride to work day for you Fitz, it will be for me! :D
  22. bigfitz52
    I wish. My freeway capable bike is winterized; the project bike still has the 7-year old weather-checked Cheng-Sh**s that came on it. Resto-fication still on schedule, but the Avons aren't happening for a week or two yet. No way am I running I-94 on the tires that are on it now. I might have to play hookey or skate early so I can get some miles down tho...
  23. NursePadawan
    NursePadawan Member
    Lansing, MI
    I pulled my bike out of the garage today, put some polish on it to protect it from the salt and went for a 30 mile ride. Temp around 40 degrees F. I actually saw three other bikes on the road :)
    Great job on the forks, Carl! I do have a brake warning light on though, but the brakes work fine, plenty of fluid in the MC. I did some emergency braking exercises and all is normal.
  24. bigfitz52
    Yep me too! Got the fusebox fixed late last night, and it was sunny and a tropical 38* F here. Got 22 miles in; love the new speedo; still amazing how much torquier the 550 is after a valve adjustment; carbs still need sorted bigtime for low speed stuff. BOY WAS THAT NICE!!! It's been a long winter. I'll post a pic as soon as we find the !^#$%&^ USB cable.
  25. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    I did 40 miles today. Lots of other bikes on the road.
    Went on a major artery for the first time. 63 mph top speed. Did a few lane changes.
    4000 rpm is about 51 mph. 5000 rpm is about 62 mph.
    I can see why some bikers go for a full frame-mounted faring.
  26. fwright625
    fwright625 Member
    Chicago, IL
    Went out today just to get the blood flowing and the wind blowing in my face. I think it was about 40 here and I just had to take her out for a quick ride. It felt so great out there that I was about to get teary eyed :D
  27. turtlemann14
    turtlemann14 Member
    its 60ish here and my bike is down :/
    is sucks
  28. tennsouthernbelle
    tennsouthernbelle Member
    Morristown, TN
    72 here and I went out for a few hours around town ^^
  29. xj650ss
    xj650ss Member
    Calgary, Alberta
    still to much gravel and ice for my liking but i did see a bike on the road the other day! mines all torn apart so i couldn't ride anyway
  30. bigfitz52
    Found the USB cable. Like I said, at only 38F today it was still a bit nippy but the sun was shining and it sure did feel good to be back on two wheels!
  31. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Gunna be low of 5 and highs of 13-15 here the next couple days :(.. too bad i don't have insurance and my M1 anymore hahah
    Oh well it's gunna rain anyways... BUT spring is just around the corner i hope :)
  32. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    Fitz, them is some seriously teeny weenie cylinders.
    Seriously, though, that is one gorgeous looking bike.
    Watch out for the slipper spots. It looks very wet all around there.
  33. protomillenium
    I rode to work Monday and Tuesday! :D But work is only 10 min.s away, and down a strait highway. :? Wish I could have taken some longer rides, because the weather's shutting down the joy again. :cry:
  34. bigfitz52
    I got yer teenie-weenie cylinders right here, pal! {just kidding} Thanks, wait until it's finished.
    It hit 61 F yesterday, I skated out early and got in some more miles. It sure was nice to be able to ride in "normal" gear rather than feeling like the Michelin Man.
  35. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    I rode Sat and Sun. Mostly I want to make sure the carb bowls are flushed at least once a week.
    Seriously, Fitz, your restos are beautiful to behold.
    I have started looking at FJ1200s and reading reviews of folks that have taken long trips on them 1 up and 2 up. If one comes up local I want to take it for a test spin.
  36. schooter
    Im at school right now i rode my bike to school today, cuz my friend rode his ninja 500 today too, the roads were a bit wet... and he has a 2 inch wide flat spot on his tire from doing burnouts... i always make fun of him for driving a lawnmower.... sounds just like one
  37. bill
    bill Active Member
    Raleigh, NC
    We are having a nice week - 40s to 50s in the morning and upper 60s to low 70s as a high. Rode to work every day so far - looks good for the rest of the week.
    Real stress reducer getting to ride home. My office is right in front of the bike lot so I can see everyone as they come in 5 out there today on real nice days there are as many as 8 to 10.
    Saw 1 guy looked my bike all around this morning. I rode all last summer so I'm surprised he has not seen it before.
  38. sushi_biker
    sushi_biker Member
    It was 70 today in Maryland. Kind of windy though. No problems, the way to offset that is to hit the twisty farm roads where hills and trees block the wind. :)
    My convalescent leave is running out so I better party while I can!
  39. Hack
    Hack Member
    Ontario, Canada
    Here's a shot from the recent storm in England to make us feel better...
  40. PaulT
    PaulT Member
    Wilton, NH
    NH seems to have moved out of the Artic air we were in. Mid 30's most days now, but still see snow/rain/ice in the forecasts :-(
    Unfortunately, I don't have a real garage to do any work on my bike, and our basement is finished, so I can't even work on parts there.
  41. alkasmeltzer
    alkasmeltzer Member
    Lincoln, NE
    Back to the original question at hand, the answer is an emphatic NOOOOOO!!!!! I am fairly sure of this seeing as I just spent 12 hours plowing snow. At least it was overtime!!! $30/hr. Ca-ching!!$$$$$$
  42. protomillenium
    32ºF today, mostly sunny. With no snow on the ground I had to go riding. That would make it -3ºF with the wind chill. I wore my WalMart ski pants. I was mostly warm enough, but after an hour of riding my fingers and toes are in pain. It started to snow shower as I got close to home, but no problem. 8)
    I think from here on I can stop using Sta-Bil in the tank.
  43. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    100 miles over the weekend. It was cool to cold but it was also dry and the roads were safe to ride.
    Rode to work today. Below freezing this morning. The bike started right up and idles perfectly. This afternoon is supposed to be 40 deg F. Its chilly but its not uncomfortable if you dress properly.
    My commute is only 5 miles each way.
  44. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Winter came back yesterday about 4" on the ground when it was almost all gone. Supposed to get to the 40's mid week.
  45. flash1259
    flash1259 Member
    W.R. Wisconsin
    :( Same here MN-Maxim . but thats ok I have a few items to replace on my bike before I can ride it this spring. Found an airshock to replace my mono shock dirt cheap . a new uni foam air filter , my front fender. then I have to re mount the headlight assembly and the horn for better fit. but too darn cold in the garage right now to do it. umm I wonder will the ol lady freak out if ibring it in the house LOL
  46. flash1259
    flash1259 Member
    W.R. Wisconsin
    Just got some more bad news . more snow for the next 6 days.
    damn I gotta move to a warmer climate
  47. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    If it wasn't it sure looked like it here today!
    Took a ride west 40mi with my neighbor. 70f little breeze not a cloud inthe sky. We were just about home close to sunset, temp dropped 20 degrees, BRrrrr, almost had to put on my gloves :) .
  48. sushi_biker
    sushi_biker Member
    It's in the 20's here in the morning, and it gets into the high 30's-40's during the day. The problem is the 20-30+ mph wind that's whipping all over the place. There's garbage cans blowing around in the streets, residual salt and gravel that make for treacherous patches all over the road. It just plain sucks.
    I can ride in the cold or the wind but not both.
  49. Hack
    Hack Member
    Ontario, Canada
    Two to four inches of wet snow in the forecast for tomorrow...it ain't over yet!
  50. xj650ss
    xj650ss Member
    Calgary, Alberta
    another 4 inches overnight, at least I know I have time to get her back together!
    Shaun
