XJ Horsepower
Discussion in 'XJ Technical Chat' started by Sonwatcher, Aug 4, 2007.
  1. Sonwatcher
    Sonwatcher Member
    Central Pa
    The other day I stopped at a motorcycle shop to get a new shield for my helmet and was talking to a guy that had a 98 Vulcan 1500. He had me listen to his pipes and his description of how nice his bike was. It was a nice bike. But I hurt his pride . He told me his bike 63 hp. I thought that was strange and I told him my xj650 was rated at 70+. He stammered back and said there was no way a bike half the motor size of his had more horsepower. I got on the web when I got home and that was true about his bike. In fact it seems to be a disappointment to the owners that it has low hp for that size engine. Is the difference because of the difference in gearing between the 2 bikes ?
    Eddieo123 likes this.
  2. pygmy_goat
    pygmy_goat Member
    Ann Arbor, MI
    Gearing doesn't affect power (except for losses). The engine generates the amount of power it does no matter the gear. Gears only exist to change the amount of torque at the rear wheel by increasing the mechanical advantage.
    Basically, there are several reasons that your bike generates more power (and mine too, hee hee), but the most important and basic is that your motor runs faster! I think the Vulcan has a redline around 6500, but your 650 probably has a redline around 10k? That difference means you are hitting each cylinder more often than he is. So, even though he has a bigger engine, you are doing nearly the same amount of work simply because you are sucking nearly the same amount of air and fuel.
    Of course, there's a lot more to it than that, but I wanted it to fit in a nutshell.
    Sean
  3. Sonwatcher
    Sonwatcher Member
    Central Pa
    Thanks for the explanation ! :)
  4. Artjim
    Artjim Member
    Arkansas
    Mines rated at 86 hp @ 9500 rpm.
    Good thing too since most of my riding is 2 up :)
    Lanpoop likes this.
  5. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
    Part of the difference could be where the horsepower is measured.
    Power ratings in cars used to be measured at the flywheel and now I believe it's measured at the output of the transmission (gross hp vs. net hp). The same may be true for bikes.
    The only fair way to compare power from various bikes is to use RWHP (rear wheel horsepower) as measured on a dyno.
    BTW, I bet that Vulcan owner would have been REALLY disappointed if he knew that a 600cc YZF-R6 is rated at 125 hp.
  6. Supernaut
    Supernaut Member
    Edmonton, AB
    Don't forget the measure of torque. Sure one can go about spouting horsepower ratings but thats only half the story at best. I'd bet that vulcan makes torque enough to twist our XJ's in half.
    Similar in the automotive world with the ricer who's proud to boast of his Honda civic making 200hp with only 1.7 liters. It perhaps only makes 120 lbs/ft of torque however. While the "x" muscle car owner hes boasting to perhaps makes 200hp and 350 lbs/ft torque from a 5.0 liter engine. Just using that as an example.
    And for a real world automotive example (sorry, still too new to motorcycles). I researched 1/4 mile times and was delighted to find that the top of the line (now discontinued I believe) Toyota Celica which is rated at 180hp, 1.8L engine, gets the same (according to data I found) 1/4 mile time as my 2004 ecotec Pontiac Sunfire, rated at 140hp, 2.2L (and half the cost I might add). I don't want to nit pick through the data but I know my sunfire is rated for 150lbs/ft of torque and I think the Toyota was about 120lbs/ft or so. However things like axle ratio and such can make up some difference but I think it paints the picture quite well.
    My XJ 650 Maxim can keep up quite well with my Uncles 1200 Harley Sportster. The difference though is that I have to make the most of my rev range while he can start to pull away in seemingly almost any gear at almost any RPM.
    If you want to go really deep into the science the hp and torque ratings at various RPM make quite the difference too. Not that I have the resources to go there now. If you want to go that deep, I don't believe peak hp is even telling half the story then really. Perhaps 1/3rd. Its a combination of hp, torque, and at what RPM they all happen (not just max but all the way through) is what tells the whole tale.... Hey anyone have a Dyno we can borrow? :p
    From what I can find that 1500 Vulcan makes 83 lbs/ft in torque and 64hp.
    And our 650 Maxims make 43 lbs/ft of torque and 71hp.
    That sounds about right to me.
    So would that vulcan guy think its some sort of marketing propaganda to say that the top superbikes make over 175hp at under 1400cc's? By his line of thinking I guess that would be impossible. I'm not sure that Vulcan character is on the right bike. His narrow line of thinking sort of brings the letters "HD" to my mind...
  7. Sonwatcher
    Sonwatcher Member
    Central Pa
    I was looking up the 1/4 mile speed stats for both bikes-
    XJ650- 12.7 122mph
    Vulcan 1500-15.33 85.8mph
    I am not sure what part the torque plays but with speed and time it seems the large amount of torque the Vulcan has compared to the XJ didn't make up for less HP. My limited understanding of this by things I've read is that though the Vulcan may have greater torque its' max comes at a low RPM where the XJ650 may have a lower torque its' max comes at a higher RMP. Because of this the XJ's engine speed is greater and produces more HP. Does this sound about right ?
  8. Stooge
    Stooge Member
    Northeast US
    Don't forget power to weight ratio. I think I offended some folks when I suggested my DRz 400 may be quicker to 60 than their 1400 v-twin. That bike was the most fun I've had on two wheels. I could get to 60 (and 5th with no clutch) in a really short space. No doubt quicker than my 80hp, 60ft/lb beemer. 550lbs vs. 280 lbs! A bike with more torque may get you there with fewer gear shifts, but the drz is a great mix of HP, grunt, and smooth shifting.
  9. Supernaut
    Supernaut Member
    Edmonton, AB
    Very true.
    Also that Vulcan probably weighs a good 200lbs more. Gearing probably set for cruising comfort rather than performance. Also apparently not enough torque to overcome the difference.
    Interesting, although I would have thought that 1500 could do at least 14's.
    It somewhat makes me wonder whats the point of sticking huge engines in some of those cruisers. Perhaps just so they can roll around with a "doesn't matter what gear you're in" sort of style.
  10. Stooge
    Stooge Member
    Northeast US
    ie: Valkyrie: Shifting=optional
    I think it's a numbers game. Everyone wants the biggest engine, regardless of such "superfluous" this as efficiencey, economy, performance......
    We are poor consumers, and classifying motorycycles by a simple three or four digit number is easier than understanding engine configuration, number of valves, final drive, intake, etc.....
  11. Sonwatcher
    Sonwatcher Member
    Central Pa
    I think with this situation that came up yesterday is helping me to more understand beyond the #'s. I think I have learned a little bit with regards to how efficiency works in regard to HP and torque with the 2 bikes at hand.
    This is my understanding. Bikes such as the Vulcan 1500 are designed to have their max torque at a lower RPM for smoother day to day driving. After the max RPM is reached the torque lessons do to the lack of ability to "breath" at the higher RPM's. This is caused by the use of smaller valves and air intake tubes that provide the best air/fuel mixture at lower speed.
    The XJ uses larger valves, air intakes and smaller cylinders that allow it to continue to breath at higher RPM's which bring about a higher HP.
    I wasn't trying to "gloat" just trying to understand myself why the difference with the big difference in engine sizes. Digging into this has helped me understand this a lot better. I really like to learn. :)
  12. Robert
    Good on you Sonwatcher, knowledge is Power! It is easy to get caught up in the horsepower game.
  13. cruzerjd
    cruzerjd Member
    Eugene, Oregon
    In a nutshell, as said above, the Big Twins have low end power for boulevard cruising and highway legal speeds. That Vulcan only makes about 54 hp but makes about 75 lb/ft torque. Good for low 0-30 times and pretty quick 0-60 times along with good 40-60 passing times, but not 1/4 mile speedsters. Our XJ's, say my XJ650 for example, makes about 50 hp and 35 lb/ft torque, runs the 1/4 mile in 12.7-12.9 and has decent 0-60 but not so great at top gear passing. All in engine design. I prefer the top end fizz of a inline four (or twin, i enjoyed my EX500 as well), to a v twins low end pull and short breath on the top end. My Xj will handle most v twins out there, there are a hand full that are as fast or faster, (not counting the Ducati's, talking about Harlerys or Harley copies). The Honda 1800 and the Harley V rod will take me alive. They either need massive displacement or 4 valve Porsche designed motors to do so though. I have a co worker who has an S&S motored big twin that can keep up with me and is probably quicker than I am, but we agreed not to talk about it after he tried to pull on me at the light and I kept up up to 75 mph. Ineresting reading though, cruzerjd
  14. pygmy_goat
    pygmy_goat Member
    Ann Arbor, MI
    I'll throw in my two cents again:
    Basically, the reason people are so obsessed with power is because it tells the story of a vehicle's engine. Power is the rate at which work is done. Work, of course, is required to make a vehicle move. A motor with more power is better.
    But, as people have said, there's more to it than that. Power isn't what makes a vehicle move--torque, or force, does. That means the more torque you generate, the faster you can accelerate, or the faster you can go at top speed, or whatever you're looking for.
    The reason, though, that power is so important, is that you can gear a vehicle, trading speed of rotation for torque. It's not a direct relationship, though, because engines don't generate equal power at all RPMs. That's why we get beaten at low speed, but as soon as we hit the power band, we begin to dominate.
    Basically, power is boss, but depending on your purposes, you might care where the maximum torque occurs. That's basically the difference between your typical rice rocket and, for instance, a Corvette, even though they might have the same horsepower.
    Sean
  15. RickCoMatic
    I love the 900's Power going Uphill.
    Leaving Concord, NH and heading North on Interstate 93-N is an adventure in Uphill motoring. Not that it's steep. Just that it is up-hill until the road finally comes to the Mt. Washing Valley.
    I go up the grade in 4th ... with the Bike purring along at ... maybe 4.5K rpm's.
    There are Hum-Vee's trying to pass.
    Harley's wanting to get by ... and the Big Yam is yawning!
    I let a guy in a Hummer get right along side and called down to the Reactor Room to lift the Control Rods out a little more as he nudged his way ahead.
    I have NO idea how economically I was making power ... but, I bet the guy in the Hummer could watch his gas gauge moving from right to left.
  16. canaweb
    canaweb Member
    Upstate NY
    ok - so.. if I'm pulling 4.5 k in my '82 XJ650, regardless of the gear.. is there a graph that can tell me the HP? If I recall.. she'll make about 71hp at about 9000 rpm...
    Seems that most of my running on the local roads is at 60mph or so or less.. so I rarely make it past 5000 rpm in 5th gear...
  17. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    I'm amazed by the level of misunderstanding when it comes to Power vs Torque, but them again I am a Mechanical Engineer so it comes naturally to me.
    HP=[Torque (ft-lbs) x RPM]/5252
    An engine that makes 20 HP at 1,000 RPM has the same amount of power as an engine that makes 20 HP at 10,000 RPM. Both engines will also have the same amount of torque when geared to have the same speed. In this example, the second engine would need a 10:1 reduction in order to have the same Power/Torque at the same engine speed as the first when operating at their peak power.
    There is a lot of physics involved with it comes to 1/4 mile times, but that is how power and torque are related. Dynamometers measure torque and calculate mechanical horsepower base on the speed at which the torque was generated.
  18. pygmy_goat
    pygmy_goat Member
    Ann Arbor, MI
    Canaweb: not really. This is just because power production is not a simple function of RPM. That's because the engine can have different loads on it. If the engine is highly loaded, you would require more force to keep it moving at the same speed.
    Imagine a truck pulling a trailer at 20 mph in 2nd gear. The same truck without the trailer moving at 20 mph in 2nd gear is traveling at the same speed, with the same gear reduction. Therefore, the engine must be operating at the same speed in both cases. However, it's intuitive that in the first case, more power is required. This power comes from a higher engine loading, meaning that more air and fuel are being injected into the engine for each rotation. More heat is generated, more work is done, and a larger amount of force is generated for each piston stroke. This translates into more force per rotation, at the same number of rotations per minute.
    Or, given the formula, as pvtschultz states:
    Doubling the force doubles the torque, which doubles the HP, since RPM was maintained constant.
  19. canaweb
    canaweb Member
    Upstate NY
    so.. assuming a 200 lb rider (me in full gear) on that '82 xj650j, which weighs 447 lbs dry..
    2 gallons of gas (13 lbs) and a few lbs for misc... on a level road.. 5th gear..
    how might I calculate the power thats being generated? Not sure how I'd calculate the torque in this scenario to plug into the formula... but it seems that the above info of rider, road and machine should be a fairly standard "load" for this machine..
  20. pygmy_goat
    pygmy_goat Member
    Ann Arbor, MI
    Yeah, I'd say it's a standard load, but it's too hard to calculate. That's because the actual load the engine has to contend with is basically a bunch of friction from moving parts and wind resistance.
    In other words, we would need more information, like how much power is lost in the gearbox (different for each ratio), what the frontal area of the bike is with you on it, what your coefficient of friction is with the air, etc., to have a picture of how much power is required.
    This is why a dynamometer approaches the problem from the other direction--they use a machine on which they know how much torque they're generating (a "brake," or some other means) and at precisely which speed, and strap the motorcycle on it, so that everything is forced to equalize. Then they know how much power the engine is producing.
  21. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I just went through this with my 2 uncles, one bought a 2002 1100 Shadow (60 HP) and the other bought a 2005 650 V-Star (30 HP), and they were amazed that my 81 650 Maxim blew them away (70+ HP) I on the other hand sat back at the finish line and laughed
  22. Supernaut
    Supernaut Member
    Edmonton, AB
    Woah this thread has been around for awhile.
    It made me wonder after hearing about the power of some of these cruisers when their owners are shocked at the power of an XJ. Surely they must be aware that there are 600cc sport bikes producing 115hp or more? And if not they must be really out of touch.
  23. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    My son has a V-Twin bike and when we ride together,... say at about 40 mph, he can just twist up some acceleration....RIGHT NOW.
    I on the other hand have to drop a gear or two to accelerate at the same speed.
    But he still envys the smooth sound of that inline 4!
    He also cant believe the way a 700 shoots right by his big 1100
  24. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    The last page of this linkhas the HP and Torque curves for an '80 XJ650. It shows a max RW power of about 48 HP so I'm not sure how accurate it is (not corrected, etc.) compared to the advertised 90+ HP, but will get you in the ballpark of what you are looking for.
  25. Danilo
    Danilo Member
    Vancouver canada
    Actually H2 's have "reasonable" fuel consumption Wayyy better than an Escalade for example.
    Big Bore Bikes are for Big Fat lazy guys Or so it seems by observation. Looking good is the intent, going fast is neither a requirement nor desired.
    Younger son's Brand New Honda 600RR aledgedly outputs 118 hp.. 108 of which actually make it to the ground, at 370 lbs 'Quick' is an inadequate descriptor.
    But I wouldn't wanna spend hours at a time on it.
    Different horses for different courses.
  26. lilhustler
    lilhustler New Member
    Whats the hp rating of my 1985 xj700n maxim?
  27. xj650ss
    xj650ss Member
    Calgary, Alberta
    I belive the 85 700 ran 86hp @9500rpm/ 49.9 ftlbs torque and mid to high 11's 1/4 mile around 112mph but keep in mind that these aren't new bikes anymore most of us are running twenty year plus bikes, I don't know if anyone took the time/money to accually dyno one but with various wear, compression etc i can't help but doubt that all these bikes still do what they once did! however i do believe especially for there time the xj line up was pretty impressive and enough so to still keep up twenty some years later!~
    Shaun
  28. bigfitz52
    A LOT of our XJs are very low mileage bikes and once gone through run just like new. It's really fun having a virtually new 27-year old bike.
  29. xj650ss
    xj650ss Member
    Calgary, Alberta
    hey fitz I'm not bagging on it i love my max but at 16000km's and 27 very likely neglected years i think a part even if just a small part of her get up and go... well... got up and went! and i doubt mine is the only one
  30. PSteele
    PSteele Member
    Nova Scotia, Canada
    Well boys, my old Max will turn 100,000 kms this year (61,000 miles) and even with everything driving it except tires original, she still runs like hell. Helli-good that is. Not sure what this translates to in HP, but all I can say is that there is still plenty of acceleration, more than enough for me to believe in the 71hp claimed by Yamaha. More unknowing riders have scoffed at my "little 650" and get impressed by the big bike sound and guts.
    This whole generation and similar offerings from Honda, Kawasaki and Suzuki all exceed expectations and I still wonder why no one makes anything similar today, or why the style died away. Great bikes! I guess this budget exclusivity appeals to me and through time, will only become more so.
  31. schooter
    power and torque are two weird things, you'd think they would go hand in hand, but they dont,really, diesels are low hp, but crazy torque, i bet you culd hook a 70 hp tractor to the back end of my dads new 6.0 chevy, with probably 5 times the hp, and out pull it, just cuz of the weight and torque, and traction.... idk, but yup looks like we figured it out
  32. xj650ss
    xj650ss Member
    Calgary, Alberta
    i guess I'll have to see once i get all the work done maybe mine will get it's jam back!
  33. lilhustler
    Thanks for the info xj650ss.
  34. xj650ss
    xj650ss Member
    Calgary, Alberta
    glad I could help
  35. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    I know a couple years back I took my 650 maxim to Englishtown, NJ Raceway Park and ran against a brand new V-Star 650 and smoked him! Needless to say he was a little hot since I picked my bike up on ebay for $750. It was awesome!
    :D
    :lol:
    :wink:
  36. FLASH4
    FLASH4 Member
    On the back wheel, in AUSTRALIA!
    You can work out what your "real world hp" is if you know the 1/4 mile time your bike "does" (not did :) ) your trap speed, and the total weight of bike with everything as is when it did the time (rider helmet fuel.. and so on).
    It simply breaks down as newton second law of motion.
    Second law
    Observed from an inertial reference frame, the net force on a particle of constant mass is proportional to the time rate of change of its linear momentum: F = d(mv)/dt. This law is often stated as, "Force equals mass times acceleration (F = ma)": the net force on an object is equal to the mass of the object multiplied by its acceleration.
    Here is a calculator to work it out, plus some other handy stuff.
    http://www.cprparts.com/HPcalculator.html
  37. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Flash4, doesn't your equation assume linear acceleration? There will be shifts, reaction times, wind, etc. that will cause errors.
    It would seem to me that the only way to accurately determine BHP would be to dyno the bike. I'm pretty sure that my liver would fall out if I ever put my bike on a dyno as any exposure I've had to this process it looks like they just flog the bejeebers out of the engine.
  38. FLASH4
    FLASH4 Member
    Actually the only way to 100% acquire a engines h/p is on an engine dyno. Rolling dynos have to many "adjustments" and "theoreticals" to be spot on. Dyno's are a great tool, but for tuning only, not for measuring h/p.
    Although you are some what correct with your statement.
    As i stated this is to work out "real world h/p". This takes in factors that a dyno could never reproduce. Such as aerodynamic drag, gear shifts, the weight of the vehicle and so on.
    Of course reaction time will disguise a minor amount of this figure but it will be minor. You could always just minus the reaction time from the trap time anyway.
    This is how it compares to a dyno:
    Say you run you bike standard and it does a 12. You put on a 4-1 and run it again. This time you get a 11.6. Jump to the website with the calculator and put in you original time and speed and weight, then put in the new figures. You have lost weight and have gained speed and lost time. This would work out to a h/p increase of say 20hp. The dyno would tell you you gain 10, but what about the weight loss? You have actually gained more than just the hp, the dyno won't tell you that.
    It all comes down to: Force = mass x acceleration.
  39. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    I see what your saying Flash, but the big question - What do our bikes weigh? Anybody?
  40. bigfitz52
    Check your service manual. That's how I know claimed dry weight for the 550 Seca is 407lb.
  41. hammerheadx
    hammerheadx Member
    Binghamton, NY
    An interesting observation about the equation above, that not many people i've met notice.
    Notice the number in the denominator of the right hand expression: 5252.
    Then look at a valid hp and torque dyno chart from a real engine run.
    Where do the two lines cross?
    5252 rpm.
    ALWAYS!
    You can use this fact to sniff out suspect dyno charts and numbers. If someone shows you a dyno graph of an engine and the torque and hp lines do NOT cross at 5252 rpm, then either the scales of the y-axis were messed with, or what you have there is a totally bogus dyno run and someone is fudging things.
    The number 5252 incorporates conversion factors, to keep the desparate units of measure aligned. Without it, the hp/torque relationship crumbles.
    Peace,
    Christopher.
  42. hammerheadx
    hammerheadx Member
    Binghamton, NY
    Another thing:
    Don't get too hung up on hp alone.
    There's a saying among gear heads that goes something like this:
    "Hp gets the glory, but torque does the work"
    Put another way, Torque is the offensive line and fullback, while hp is the running back. Sure, it's nice to have a speedy, flashy tailback, but he's not going ANYWHERE without the grunt up front.
    Gimme some solid torque anyday. In drag racing, torque is king, not hp.
    As stated earlier in this thread. Hp is imaginary. That is to say, torque is what your measuring. hp is a calculated number, based on that torque.
    Cheers,
    Christopher.
  43. Deadulus
    Deadulus Member
    Dufur, Oregon
    It may be a bit simplistic but.... :grin:
    If Im riding my 29 year old bike and its running well because I made it run well and Im smiling every mile of the way.....my last care is horsepower.
    I dont mean to belittle the discussion, but thought Id put my .02 in.
  44. baz666
    baz666 Member
    Washington, DC
    The Vulcan's 2 cylinders and yours is 4. Kind of like the difference between a big 4 banger and a small V8.
  45. hammerheadx
    hammerheadx Member
    Binghamton, NY
    Deadulus has the wisest take in this thread.
    My helmet is off to you sir.
    I also dig the userid and the attendant irony therein. :wink:
    I went for a 40 mile ride yesterday and just enjoyed the ride. No pressure to be the fastest hooligan on the road, like i used to feel on my Ninjas or ZRX1100.
  46. baz666
    baz666 Member
    Washington, DC
    Enough already about 4 cylinder XJs "smokin' " small displacement v-twins. You have twice as many cylinders. Now cut that in half and you'd have a thumper against a V-twin. Who do you think would win? My KLX650 Kawi single cylinder had 38hp stock and was useless off the line. But that's not what it was built for. Not all bikes are built to run 1/4 mile times.
