please help me with my speech
Discussion in 'XJ Technical Chat' started by etg29, Feb 17, 2009.
  1. etg29
    etg29 Member
    Normal IL
    im in college and have to do an informational speech for my speech class. i decided on doing a speech about what all hapeens in the few seconds between you putting the key in a XJ series bike and it happily idleing away at 1050 rpm +-50 rpm. anyone like to help me??? as many details as possible
  2. wizard
    If the bike is like Andy0418s, nothing hapeens. :lol:
  3. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Dude!!!! That's cruel!!!!!
  4. mirco
    mirco Member
    LaGrange Ohio
    Very few things in life come close to the excitement of motorcycling (opening remark).
    Even as you walk to the garage to unleash the beast you are ticking down the mental checklist that is part of the enthusiast's every ride.
    Gas? Oil? Air pressure in the tires?
    Then the donning of the gear begins. Frosty mornings require additional preparation; insulated Carhart coveralls, gloves, helmet liner, quick spray of "anti-fog" on the visor and you swing your leg over the saddle - always mounting from the left side of the bike (must be a throwback to the days of riding horse?)
    The aniticipation builds as you reach for the ignition key and you feel the familiar butterflies in the stomach. Most mornings are still dark when you head off to work (school) and as you turn the key and the engine begins to turn over the single headlight comes on and pierces the darkness in a kind of "otherworldliness" and it all plays together to make your senses come alive and you feel as exhilirated as if you just snorted coke.
    Then the engine catches and its steady thrumming between your legs fills you with desire that can only be satisfied by tapping the shifter into gear and with a few cracks to the throttle to speed the warm up you never felt more ready to face the adventures of a new day.
  5. wamaxim
    Vancouver, USA
    Geez! Is that what happens?
  6. Ltdave
    Ltdave Member
    having ridden in The Blue Knights (LE only) i can tell you that ive gotten into the habit of mounting from the right as taught by a cumulative 125yrs of experience...
    2 guesses as to why motor-cops mount and dismount from the right side...
  7. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Take-out window at the doughnut shop is on that side? :lol:
  8. etg29
    etg29 Member
    Normal IL
    ok what i meant was what mechanically happens not the mental stimulus
  9. wizard
    Well egt, you havn't exactly hit a rich seam of intellectual stimulation here.
  10. stevetibb2000
    stevetibb2000 Member
    bakersfield
    well it starts then it dies
    ohh crap i forgot the choke
    them verrrrmmmmmmmmmmmmmmmmmmmm
    ahh crap the idle screw is to high kill the engine
    hmm ohhh i didn't turn on the fuel
    put it to pri
    well it starts vermmm vermm vermm
    let it warm up
    take the choke off
    then it dies crap no gas
    walk down the street to go get gas
    put the gas in
    then it starts
    all right get my gear on my gloves on my jacket on ahh crap i have to take off a glove to button up my helmet
    look to the left
    look to the right
    make sure my turn signals work
    push left ok good push right ok good
    push in my horn waaaaweewaaa man that sound like a dieing cow
    i open up the grage door
    i pull in the clutch and mount form left to right
    i walk the bike back wards then i push in the rear brake
    it stops me
    then i push in the front brake it stops me
    i turn around the bike
    i push down the shifter to first
    then i rev the motor then slowly let go of the clutch
    as i pull away i pull up the shifter to second
    ahhh crap im out of time ill do this later
  11. flash1259
    flash1259 Member
    W.R. Wisconsin
    I squeeze the clutch and hold it in then I turn the key in extreme anticipation, a click, a spark, and then a multitude of explosions manifesting between my legs with a roar and a vibration to excite any man or woman who is able to tame it.
    I release the clutch andhang on for what its worth as I Shift the beast to higher gears it feels angry and hungry for the taste of the road. The twist of the throttle, the injection of fuel and again More explosions moving me faster at my will.
    The rush of the ride and the wind in my hair is finished as I reach my goal I Grip the brake and roll to a stop, I then twist the key back and the excitement ends just as fast as it had started only to repeat itself time and again.
    ( did you want a more detailed version detailing the TCI and Regulator?)
  12. etg29
    etg29 Member
    Normal IL
    more of a technical expanation of what happens basicly the the TCI Ignition system
    ive kind of got an idea of what goes on this is what i got so far:
    key is turned to on
    gets tci ready???
    push in button completing the starter motor circuit
    crankshaft starts spinning
    crankshaft gets camchain moving
    cam chain spins up the camshafts triggering certain cylinder(s) to intake fuel/air mixture
    the engine pickups? send signals to the TCI ?
    TCI sends current to the coil specifed ?????
    coils creates spark in cylinder that has already intaked specified by the TCI's selection
    ignition of cylinder(s)
    engine starts to repeat the same process over and over
    rider opens the starter motor circuit
    engine idleing at 1050rpm +-50rpm
    i know ive got to be missing something???
  13. TheHound
    TheHound Active Member
    Scotia, NY
    It must have to do with night stick or pistol smacking the bike.
  14. Big_Ross
    Big_Ross Member
    I always get on the bike from the left hand side, but we drive on the left, so if you're parked parallel to traffic, getting on from the right means you're out on the road and nearer the cars. I would have assumed that in countries where people drive on the right, you would get on from the right.
    Incidentally, if you want a laugh, sit on the Thai/Lao border for an hour or two. Drivers have about 100 yards to change sides. Many don't!
  15. bigfitz52
    Wow. I never even thought about it, but I almost instinctively get on from the left too. Then I gave a LOT of thought to why, and came up with this:
    Back in the day, virtually ALL motorcycles had kickstarters. Every kick-start bike I ever rode (mostly all British) had its kickstart lever on the right. You mount from the left, putting your left foot on the peg and stand up to bring your weight down on the kickstarter.
    Which then makes me wonder if we all got into a bad habit because our bikes came from a place where they drive on the other side of the road?
    And why do people who never rode kickstart bikes do it?
    (sorry to hijack your thread, I can help with the startup sequence thing but it will have to be later)
  16. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    When I took the Safety Course, they told us to get on always from the left, because if you slipped/fell your going to fall on the left side and because of the kick stand, you can't pull the bike onto yourself.
  17. bill
    bill Active Member
    Raleigh, NC
    OK lets see if I can help by adding ot your sequence
    Turn on switch - allows power to TCI and other ignition components
    the engine pickup sends a signal to the TCI
    coils creates spark in 2 cylinders one of which has just completed it's compression stroke
    Simplified but fairly accurate - hope that helps
  18. mirco
    mirco Member
    LaGrange Ohio
    With the bike leaning to the left because of the kickstand, it would be extremely difficult to mount from the right. Do the police motorcycles switch the side that their kickstands are on - because if they don't I have a hard time believing that you can lean a HD to the left and then dismount from the right especially considering that most motorcycle cops are short (after all, little man syndrome is what motivated them to join the police force in the first place :).
  19. TIMEtoRIDE
    The Harleys also have both hot exhaust on the right, scorching the pant legs! How's this: The cop gets off the left after pulling someone over. He's a bit nervous and distracted with radio communication, the chase, grabbing the ticket book, he somehow falls off the left, and his head ends up in the slow lane, across the white line.
    Anyway,
    The acids in the battery react with lead to free electrons, shoving them down the line, past the crusty fuse box and the previously mentioned relays, straight to the starter windings, creating magnetic fields that ultimately spin the motor. . .
    The vacuum presented to the Pilot port draws fuel from the bottom of the float bowl, blending the fuel with a little air along the way, and squirting it down the hungry throat of the motor.
    The oil pump starts working too.
  20. schmuckaholic
    California
    The kickstand is on that side. Ergo, that's the way the bike leans. Would that have something to do with it, you think?
    Then again, that raises two more questions:
    1) WHY is the kickstand on that side;
    2) Why do we get on the bike from the left side, even when the bike is on the center stand?
  21. etg29
    etg29 Member
    Normal IL
    how did this thread get so off topic????
  22. tennsouthernbelle
    tennsouthernbelle Member
    Morristown, TN
    HAHAHAHAHA sorry... hahahaha
    I think you just turned me on.....
    Sorry we hijacked your thread.
    I have no idea what happens, I turn the key, I choke it, I hit the starter... if that doesn't work I call my uncle.
  23. Polock
    actually the TCI opens the circuit to the proper coil, magnetic field collapses
    inducing voltage in secondary windings, firing two sparkplugs
  24. etg29
    etg29 Member
    Normal IL
    it opens the circuit i thought it would close the circuit on the coil thus pushing current the coil??
  25. Stamplicker
    Stamplicker Member
    London Ontario
    Now, wouldn't the first thing be, the battery has a charge? if not.. your first thought is CRAP!!!! I"ve got to push start this Freak'n thing.. so now.. is it the gear engaging?
  26. etg29
    etg29 Member
    Normal IL
    ah your right i will have to add the battery to the list
  27. Polock
    it's a long story but the voltage is proportional to the speed of the magnetic field, it's faster collapsing than expanding
    remember ignitions with points ? never mind, your too young :)
    plug fires when points open
  28. etg29
    etg29 Member
    Normal IL
    i get it it gives off a high voltage charge coming out of the coils that flows down the wire through the cap to the sparkplug and creating a quick high voltage spark ...am i on the right track....
  29. etg29
    etg29 Member
    Normal IL
  30. etg29
    etg29 Member
    Normal IL
    now i just need a detailed description of how the TCI works?
  31. Polock
    got me there, has something to do with the ignition pickup coils down on the crankshaft end sending a voltage to change the bias of the T's in the TCI...?
  32. wizard
    Plagiarize this
  33. etg29
    etg29 Member
    Normal IL
    thanks for the info wizard. so the TCI is operated by magnetic pickups on the end of the crank right? (i know im pushing for alot of info, but i dont want to go in front of the class and try to BS my through it, i have in the past though, but this is a topic i cant BS)
  34. chacal
    I believe that it's all gremlins and ghosts and puppy-dog tails inside.
    But if not, then maybe this will help:
    http://home.ptd.net/~theragos/tci%20faq's.htm
  35. etg29
    etg29 Member
    Normal IL
    so from what i gather a tci in a nutshell is this:
    1.a Transistorized Coil Ignition
    2. does the following things:
    A. detects when the magnetic pickups have passed the sensor(s)
    B. acts to cut off current to a coil to collapse internal magnetic field of a coil thus creating a huge surge of high voltage current that is sent to the spark plugs that are located in the cylinders that are in or close to(depending on RPM) TDC(top dead center) position, one cylinder being in the exhaust TDC and the other in the compression TDC
    C. advance ignition timing in accordance with engine RPM to compensate for less TDC time as RPM increases so that spark happens at aproximatly TDC
    Does this seem ok to you guys?
  36. bigfitz52
    Yep. Except it isn't trying to actually fire at TDC, there is a pre-determined amount of "advance" built in, optimized to the particular engine. That's why you shouldn't use a 650 TCI box on a 550, for instance.
  37. wizard
    Etg, now you are getting on top of your subject, well done.
  38. bill
    bill Active Member
    Raleigh, NC
    Looks like another successful rescue from the hijackers 8)
    Although that is a very interesting topic - perhaps a new thread?
  39. chacal
    Nope! Go read the info at the link that I posted, and you'll have a much better (and simpler) understanding of the whole thing. Pictures, too! Even a video.........
    A research report, eh? Then recall the secrets of the great researchers from ancient times:
    Plagiarize......
    Let no one else's work evade your eyes!
    So do not ever shade your eyes,
    But plagiarize, plagiarize, plagiarize!
  40. Polock
    what about all the interlocks ?
  41. etg29
    etg29 Member
    Normal IL
    what are interlocks???
  42. wizard
  43. etg29
    etg29 Member
    Normal IL
    nope i havent got a dui yet so i dont have to worry about that
  44. TIMEtoRIDE
  45. etg29
    etg29 Member
    Normal IL
    thanks guys for all the help the speech went good a i got an A :) heres a picture of my art work on the whiteboard(excuse my lack of drawing skills)
  46. flash1259
    flash1259 Member
    W.R. Wisconsin
    Congratulations on the "A".
  47. bill
    bill Active Member
    Raleigh, NC
    Cool Congrats!
  48. TheHound
    Scotia, NY
    The smart kids ride XJ's :D
    :arrow:
