How much oil does your bike consume?
Discussion in 'XJ Technical Chat' started by TriHard, Feb 22, 2009.
  1. TriHard
    TriHard New Member
    Dunsborough, Western Australia
    After a run of around 30 miles my oil warning indicator comes on. Not riding it exceptionally hard, motor doesn't leak oil, doesn't seem to blow any smoke. I know it must be coming out from the exhaust but at this rate, I need to carry oil onboard for any decent ride length.
    The engine compression is 120psi across all 4 cylinders.
    Any comments? Anyone with similar consumption?javascript:emoticon('post',%20'message',%20':(')
  2. alaskazzr
    alaskazzr Member
    Anchorage Alaska
    Is the oil level actually going down?
    At first blush, it sound more like a sensor problem than an actual oil loss scenario. It happens a lot on the oil quantity sensing systems on the C-130's I work on.
  3. bill
    bill Active Member
    Raleigh, NC
    Are you filling the oil to the top of the window? you shouldn't eat that much oil. Mine has 42k and doesn't burn any that I can tell. Compression is 140 on all 4.
  4. bigfitz52
    If you have good even compression on all 4 and it IS eating that much oil, either your breather is plugged up causing massive blow-by or you could have one or more bad valve guide seals. Either way, if it really IS using that much oil, I would think it would also be blowing smoke.
  5. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Wow, that would be alot of oil use. I've gone 700+ Km riding at 120km + the whole way and only burn maybe 150ml-200ml. So by the sounds of it your getting blow by on the valve seals.
  6. TriHard
    TriHard New Member
    Thanks gentlemen for your advice.
    I'm inclined to think it may be a faulty sensor / float, as per alaskazzr's post.
    The warning light tends to come on when I accelerate really hard, then stays on. Maybe the float is sticking? I'll drain the oil and pull out the sensor. I can't see the oil level through the sight glass.
    The whole story is that I would ride, oil warning light would come on, return home and refill. This happened two or three times. As I couldn't see through the sight glass I would guess as to how much oil it needed, topping up with maybe 500 mls. Then one day after a good ride I arrived home and oil flooded from the air cleaner box (oil warning light on). I drained the oil and collected nearly 5 litres. My original post regarding this problem had many members suggesting that a fuel float was stuck and fuel mixed with the oil hence the overflow. This may still be the problem but now warrants further investigation. (Perhaps I couldn't distinguish the oil level in the sight glass because it was already full???) I look forward to solving this one. If anyone has had a similar problem I would be interested to hear from them.
    Cheers,
  7. flash1259
    flash1259 Member
    W.R. Wisconsin
    Trihard better check to see if you over filled your oil . if you did it will eventuall end up in your carbs. I found an engine cleaner for motorcycles that is supposed to clean youe engine real good, it will even get the gunk off the sight glass.
    http://www.auto-rx.com/cycle-rx/application.html
