I Need some help
Discussion in 'Hangout Lounge' started by stevetibb2000, Feb 23, 2009.
  1. stevetibb2000
    stevetibb2000 Member
    bakersfield
    I know i dont have an Xj anymore But the RADIAN YX600
    is pretty much the same but with out the YICS
    OK for starters it runs and pulls hard every thing on the bike is stock even the 4 into 2 exhaust
    this is what i have done
    new float needles
    new gaskets
    carb sync
    tones and tones of carb cleaning the queen Mary would eat off these things if it did not have the smell of gas
    i replaced the carb piston diaphragms
    i did not over service the air filter
    ive adjusted the polite screws the gearing is correct the cluch plates are new new throttle cable
    new clutch cable new choke cable
    but my problem is this is a 130MPH bike stock
    but i have to WOT to get to 82.3MPH and then i start to loose RPMS and it feels like it wants to bog
    ive checked the fuel levels after i did a float adjustment
    the floats are good
    the main jet is 97.5
    there is no fuel restriction at all it has a good sealed gas cap
    im not trying to to race this bike or anything i just want the power if i need to get out of the way of something
    should i get a dyna jet kit to stage 1 or 3 there is something wrong
    i just dont know could it be the TCI
    And Robert the Past owner said it had a good compression
    i checked the valve clearances and there in speck
  2. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    sounds like the bike is not getting enough air in the mixture.
    or not atomizing well
    After running the bike WOT, I would suggest a WOT plug chop.
    overly rich main circut could cause your symptoms.
  3. Robert
    Steve, now that you have run it through some heat/cooling cycles, I'd be very curious to know what your compression looks like now. Something else to do next time you drop by.
  4. stevetibb2000
    bakersfield
    when would be a good time for me to come down there
    and i also knoticed that it sucks a lot of fuel maybe 60 miles to the tank
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Oh My!
  6. stevetibb2000
    bakersfield
    and there is no leaks
  7. Robert
    You need to do a plug chop check and see what is going on in the cylinders. From the sounds of it you are WAY too rich. What does the drop idle test tell you? Snap the throttle open after it is warmed up and note what happens to the rpms as the throttle closes and the engine winds down. Does it respond crisply, returning to a smooth idle quickly? Or does it wander down to idle, rather slowly, possibly stumbling upon throttle twist? If you are experiencing the latter, you are too rich for sure.
  8. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
    Sounds like a good way to avoid a speeding ticket to me.
  9. stevetibb2000
    bakersfield
    ah ha but 3 of the 4 plugs are a good tan color and the 4th one is a little sooty black from being to rich
  10. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Gas getting into yer oil? bad petcock?
  11. stevetibb2000
    bakersfield
    new petcock sorry
