92 XJ600 Battery charging problem
Discussion in 'XJ Technical Chat' started by Death4Angle, Mar 5, 2009.
  1. Death4Angle
    Death4Angle New Member
    Hay my this is my first bike. I dont know what it is called on a bike but on a car its call a alternator, My bike is not charging my battery and i am needing to know what i need to check or get fill free to post comments and Questions. I am also looking for (screws and bolts for the plastic Pieces on my bike and one screw on a carb)
  2. bill
    bill Active Member
    Raleigh, NC
    Re: 92 XJ600
    Welcome. PM Chacal for most parts - see his posts in XJ4EVER topic.
    A good manual is a great place to start. You can check your generator by metering the battery. At above 2k rpm you should see about 14.5V or so.
    Beyond that you can have a rectifier or diode issue. need ot see if charging is the problem then start working back.
  3. Death4Angle
    Re: 92 XJ600
    its a 92 and only 9k miles runs grate just dont charge battery any more and i just got a new battery its 14 V
  4. TheHound
    TheHound Active Member
    Scotia, NY
    Re: 92 XJ600
    You can check the brushes in the alternator, there's a thread around here outlining the max min lengths.
  5. Death4Angle
    Re: 92 XJ600
    i will take a pic of it and post it to show u guys
  6. Death4Angle
  7. Death4Angle
    Re: 92 XJ600
    should i just get some sand paper and sand the top layer off the metal contacts ?
  8. Death4Angle
    Re: 92 XJ600
    can some one give me more feed back ?
  9. Tito
    Tito Member
    Barto, PA
    Wish i could help. I haven't delt with this issue.....yet
  10. Death4Angle
    well makes me mad cant drive my bike any where initial i get it fixed....
  11. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Death, you are not looking at the brushes. You are looking at the stator. The brushes are little rectangular silver gray doohickeys with a wire inside a spring. They ride on the commutator which is part of the rotor. There are usually only 2 of them. Look up alternator through Google and you should be able to find a picture. Better yet get a manual.
    Wamaxim
  12. David3aces
    David3aces Member
    St. Pete Fl.
    That model has a permanent magnet rotor. There are no brushes. Check idle voltage across three wires from it. From wire to wire not to ground. (3 combinations) Important for all to be the same AC voltage 15-20 volts or so. If good than change rectifier/ regulator assy. Check AC volts not DC volts from stator.
    Older XJ models have brushes that make an electro magnet out of the rotor. This can be checked with a thin feeler guage outside of the cover by holding guage close to cover and turning on key. If it attracts guage to cover, rotor, and regulator part of rectifier are working. Regulator adjusts voltage to the rotor changing the amount of magnatism. Not output of stator.
    This newer XJ600 regulates output of stator.
    This is one of the few things I remember from the Yamaha schools I went to 28 years ago.
    Good luck.
  13. Death4Angle
    i dont have no gauge or meter so im just going to have to charge battery up and take it to a shop hoply they dont fix the bike and me up with a big bill.
  14. David3aces
    David3aces Member
    St. Pete Fl.
    Man, if you are able to that that much of the bike apart, you are able to fix it. You can buy a volt meter for about $15. it's easy to check. We can walk you through it. You need to re assemble it to test it.
  15. Death4Angle
    ok next time i go to harbor frate i will get one .....walking
  16. TheHound
    Scotia, NY
    Harbor frieght has Digital multimeters on sale this week $2.50.
    Meter
