Has anyone used HONDA Carb cleaner spray..instead of SEAFOAM
Discussion in 'XJ Technical Chat' started by littlegiant, Apr 19, 2009.
  1. littlegiant
    littlegiant Member
    Toronto, Canada
    Just wondering if i can use the Honda carb cleaner spray in to the intake instead of SEAFOAM. Guess it should do the same job. Any comments appreciated. thanks
  2. trekrider
    trekrider Member
    lancaster PA
    you can use walmart brand it will give you the same result, less money :D
