I Got another maxim!!
Discussion in 'XJ Technical Chat' started by Aschulhoff, Aug 20, 2006.
  1. Aschulhoff
    Aschulhoff Member
    Richmond, Va
    so searching around E-bay i ran into a 1981 maxim 550 close enough for my to pick up. I won the auction at $68.00 cant beat that.
    Clean title, and decent shape bike.
    Some things had been parted off it and it looks to have been laid down once.
    It’s missing:
    carb boots air box side
    start stop switch and throttle handle
    throttle cable is broken
    all 4 turn signals, but in Virginia you don’t need them
    tank cap
    ignition
    ignition plastic cover
    keys
    left side plastic cover below seat
    tank emblems
    door for the under/behind seat tool box
    exhaust pips/tips but the heads are still on the bike
    fuse box
    front forks need oil and may need to seals
    center stand
    mirrors
    In bad shape:
    rear springs are near shot
    breaks are out, thinking there is a leak in the line
    carbs are gummed up bad, but i'm cleaning them now
    some rust on the frame
    some rust and scaling in the tank
    front head light holder looks questionable
    rear tire is bald but holding air, front tire is flat and may hold air
    Perks:
    Hotwired with a starter switch mounted on the right side cover (it works)
    bike turns over
    fresh powder coat on tank and rear fender
    Seat and back rest in good shape
    I was going to use it as a parts bike for my 1982 maxim 550, but after hearing it turn over I think I am going to try and restore it.
    What do you all think?
  2. ROBBY
    ROBBY Member
    PLYMOUTH,MA
    I thinkl I'm jealous.
  3. kbarmansr
    kbarmansr Member
    Northern Ohio
    I am thinking you got a good deal, come across any others let me know wil ya... thanks
  4. Robert
    Sounds like a good parts bike to me. You'll sink a few hundred dollars getting all the missing stuff (unless your particularly resourceful and a good barter/trade guru). Best of luck which ever road you choose, your bound to have fun either way.
  5. Joel07
    Joel07 Member
    Durham, NC, USA
    Wow, just looked at your location, I'm guessing you had to go north to get the bike? Usually anything south of Richmond goes for big bucks, and for some reason stuff north of Richmond is much cheaper. Good find!! I always figure with a deal like that, you could always part it out and MAKE money on it, so it can't be a bad deal. At least that's how I rationalize buying all these bikes anyway... :lol:
  6. Aschulhoff
    Aschulhoff Member
    Richmond, Va
    hahaha exactly... but once i get my hands on a bike, i just can't bare to part with it... The bike was east of here, in Hampton just befor going threw the bay tunnle... which worked out so so well since i was already going threw there to see familly at VB it just so worked out that i could pick it up the day i was heading to the beach... the guy was so nice, he even loaded it on the truck for me which would hav been a task on my own heh.
