1982 XJ650RJ Seca For Sale (Seattle area)
Discussion in 'For Sale, Trade/Swap, Wanted' started by Deadpedal, May 15, 2009.
  1. Deadpedal
    Deadpedal New Member
    650cc inline 4 cylinder
    Dual front disc brakes; rear drum
    Koni rear shocks
    Shaft drive
    Lockhart oil cooler
    Upgraded to blade style fuse panel
    Genuine Yamaha factory service manual
    24k miles
    Clear title in hand
    Tabs good through 11/2009
    Test rides permitted so long as you have a current motorcycle endorsement, helmet, and cash in hand.
    $950
    Needs the usual long-term bike maintenace: valve adjustment and carb clean/sync. I believe one of the carb boots also has a small leak which is causing a loss of vacuum. The valve cover gasket has a small leak (easy enough to replace when the valves get adjusted).
    This bike is in good overall condition for a 27 year old motorcycle. It has some minor dings here and there but nothing you wouldn't expect from an unrestored vintage bike. I bought it a little over a year ago with the intent of resolving the maintenance items and taking it on vintage group rides, but I haven't been able to make time for it, and need to free up some garage space.
    Includes the following extras:
    * Lockhart aftermarket oil cooler.
    * Hard to find genuine Yamaha factory service manual (not a re-print).
    * The XJCD v4.0.
    * New factory replacement decal set, perfect for if you choose to repaint/restore the bike.
    * Extra front fender.
    See CL ad for pictures, more details, and contact info: http://seattle.craigslist.org/sno/mcy/1171757895.html
  2. Deadpedal
