Cleaning the face shield
Discussion in 'XJ Technical Chat' started by minturn, May 18, 2009.
  1. minturn
    minturn Member
    colorado
    What do you use to clean the bugs off your face shield?
    I worry about scratching the surface.
    Thanks.
    Jim
  2. bill
    bill Active Member
    Raleigh, NC
    I use a windshield polish made for plastics. But windex and a soft cloth works just as well
  3. bigfitz52
    I take a paper towel, fold it in half the long way and saturate it with Windex. Then I lay it across the shield and leave it there for 5-10 minutes while I find my gloves, sunglasses, etc. Once it's had a chance to soften up everything, it will wipe off with one or two passes; less chance for scratching.
  4. bill
    bill Active Member
    Raleigh, NC
    Hey Fitz that's a good trick.
  5. mikeg
    mikeg Member
    Milton, Vermont
    That's why I love this site! Thanks for the tip Fitz, I'm going to have to give it a try.
    mikeg
  6. hammerheadx
    hammerheadx Member
    Binghamton, NY
    Even though they say it's not for plastics, i've been using Rain-X on my helmet visors AND my windshields for YEARS.
    Three benefits:
    1. Rain visiability
    2. If you wipe them off as soon as you get home, bugs just slide right off with a little windex and paper towel.
    3. Rain-X actually fills in minute scratches and makes the surface smoother.
    I've never ruined a visor or windshield yet. I currently have a Slip Streamer Spirit windshield on the XJ and don't go anywhere without Rain-X on it.
    Of course, use at your own risk...
  7. bill
    bill Active Member
    Raleigh, NC
    I have used Rain-x in the past with no ill effects but the warning put me off. The windshield polish I have has some of the Rain-x properties. Its a cleaner/polisher.
  8. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    While we are on the subject ...
    How do you get rid of small scratches, particularly on one of the mirror-like visors ?
  9. 86xj700_indy
    86xj700_indy Member
    i have taken mine to a shop that specializes in windshield recoating and they can fix it for you in a few minutes and for almost nothing
  10. stereomind
    stereomind Active Member
    Tulsa, OK
    Meguiars Natural Shine will make them a lot less noticeable for a while...
  11. bigfitz52
    I use Brillianize (a clear plastic polish) to remove minute scratches.
  12. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Novus scratch remover works good.
  13. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    A little off topic, but if you have problems with the shield fogging up, put some shaving cream on the inside.
  14. XJDriver
    XJDriver Member
    Sacramento, CA
    I have used lemon Pledge furniture polish before, seems to work great also. takes a little but more rubbing to ensure no streaks on the face shield but it gets it clean. also works good to polish the rest of the helmet.
  15. Lisak
    Lisak New Member
    We use Mothers Wax on the recommendation of an Apple Auto Glass shop , they used to stock specialty products but the owner says Mothers works just as well for a quarter of the price - it makes the water run off both the windshield and the visor, fills in scratches and it smells good. He uses it on his stock cars and just re-applies when needed. Anti - fog on the inside that came from the Yamaha dealer.
  16. Kiwi
    Kiwi Member
    New Zealand
    That's the great thing about an HJC helmet, there website recommends the use of Rain-X products on their visors.
  17. TheHound
    TheHound Active Member
    Scotia, NY
    I use the Meguiars clear plastic cleaner & polish.
    Took the yellow off the headlights no problem.
    Works on scratches too.
  18. wamaxim
    wamaxim Active Member
    Vancouver, USA
    +1 on the Lemon Pledge. It also helps at carcass removal time and has the added advantage of making the inside of your helmet smell lemony fresh!
  19. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    I've heard it's better to use cloth than paper.
    The theory is that paper, which is made from wood, it's harder than the plastic surface, and will scratch it. The more coarse the paper, the worse the scratches. Picture scrubbing some some corregated cardboard around on there... 8O
    Not telling you to stop using paper, but just passing along some anecdotal info.
    YMMV, but I've since switched to a cloth towel instead of paper towels. :D
    Burnarr
  20. stormothecentury
    stormothecentury Member
    Rochester, NY
    Yeah, but doesn't that make it hard to see?!? :lol: :wink:
    Seriously though, just apply it, let it sit for a couple of minutes, then wipe it off?
  21. NursePadawan
    NursePadawan Member
    Lansing, MI
    I use Plexus, works great.
  22. bill
    bill Active Member
    Raleigh, NC
    I just got a new windshield and it recommend waxing it but says NEVER use spray furniture wax. Does not say why. I wonder if there are long term effects?
  23. bigfitz52
    I suspect a product made for furniture that lives INSIDE would not hold up well when exposed to the elements OUTSIDE.
  24. bill
    bill Active Member
    Raleigh, NC
    Could be - it is interesting as they go on and on about not scratching the lexan and keeping it clear and clean, then make that statement.
    Anyway I bought the windshield cleaner because it is safe for lexan - Worth a couple of bucks more to me. I'm going to have to try the shaving cream antifog. I have not found one I thought worked well yet.
  25. tumbleweed_biff
    Gahanna Ohio
    I suspect it has to do with the spray propellants and their effects on the windshield material.
  26. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    Yep, It's an old dirt track racing trick.
  27. ktcubed
    ktcubed Member
    St. Augustine, FL
    Shave cream works on the bathroom mirror also...
  28. tumbleweed_biff
    Gahanna Ohio
    Well, you could also use spit - an "old" diver's trick ...
