12 months of work. Here she is!!
Discussion in 'Hangout Lounge' started by cturek, Jun 14, 2009.
  1. cturek
    cturek Member
    O'Fallon, MO
    Bought not much more than a parts bike last July.
    Many enjoyable hours later, here she is. Meet "Jezzabelle". What do you think?
    Here's what I did to it:
    Installed stock air/fuel jets
    Installed stock Y-13 needles
    Changed carb bodies to bodies with fine threaded mixture screws
    Replaced missing lower carb bracket with idle adjusting screw
    Cleaned/Rebuilt Carbs including throttle shaft seals
    Adjusted valves
    Changed Oil/Filter
    Changed Air Filter
    Discarded corroded collector box, headers and aftermarket mufflers
    Installed new (from eBay) stock headers, collector box, mufflers
    Installed new header seals
    Removed cam chain slack
    Checked compression
    Replaced airbox boots with new Fernco boots
    Installed new valve cover gasket
    Installed new valve cover pressure washers
    Replaced right side engine cover
    Installed inline fuel filter
    New spark plugs
    derusted tank
    Installed new front/rear tires
    Installed new tire valve stem cores
    installed new front brake pads
    Installed new rear brake shoes
    rebuilt front master cylinder
    rebuilt front brake calipers
    installed new front brake hand lever
    Installed new fork seals/dust wipers/cap orings
    Installed new fork oil
    pressurize forks to 10 psi
    Checked level of rear differential lube
    Replaced missing mirrors
    replaced missing fasteners
    Checked coil/pickup resistances
    Checked regulator/rectifier resistances
    Installed new alternator brushes
    cleaned all connector contacts
    Installed new Fuse holders/fuses
    Installed new blinkers
    Installed new headlight lamp
    Replaced missing start button
    fixed horn wiring
    Installed automotive flashing unit
    Installed battery tender lead
    Painted carb hats
    polished alloy covers
    Painted tank and body parts
    Added gas tank seam trim
    cleaned frame
    painted front and rear wheels
    Painted front brake rotors
    Painted frame
    Painted center stand
    Restored plastic parts Back to Black
    Cleaned motor
    Going to do a better job on the motor next winter. But for now, it's time to ride.
  2. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Very very nice job. I appreciate one going back to near as stock as possible - no offense to the bobbers.
    What size is that back tire?
  3. cturek
    cturek Member
    O'Fallon, MO
    Thanks SecaRob. It's a 130/80.
  4. luckyll
    luckyll New Member
    Moncton, NB, Canada
    Beautiful... Simply beautiful :D
    Thanks for posting the before-and-after pics, it makes one truly appreciate the work you've put into this. Probably looks even better now than it did when it first rolled out of the showroom!
    Great work.
    Cheers,
    Lucky
  5. PSteele
    PSteele Member
    Nova Scotia, Canada
    Nice, nice work cturek...simply much more patience (and time) than I will ever have. I'll have to keep an eye on EBay because my Maxim needs pipes and mufflers.
    Congratulations!
    Pete
  6. skeeter
    skeeter Member
    Iron Mountain, MI
    very nice.
    was the tank seam trim on the stock bikes (my seca has no tank trim - just wondering if it used to . . .)
    looks good.
  7. CJ06XLT
    CJ06XLT Member
    Southwick, MA
    Wow!
    That ride looks brand-new! Awesome job, hope I can get mine looking half that nice.
  8. dwcopple
    dwcopple Active Member
    bay city, michigan
    nice work! feels good doesn't it?
  9. kontiki
    kontiki Member
    Columbia, SC
    Fantastik man! Excellent job she looks gorgeous. My Maxim is down fore a while so I can do a complete carb rebuild and a bunch of other stuff. I'm hoping she'll look as good as yours when I'm done.
  10. bill
    bill Active Member
    Raleigh, NC
    Very cool - great looking bike congrats on all your hard worlk paying off.
  11. mlew
    Very nice- job well done. Can I send you some of my old parts so you can make them look new again?
  12. helmet
    helmet Member
    that looks damn nice! wanna trade for my 85 700?
    didnt think so
    *kicks dirt
  13. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Very nice job!
  14. Hack
    Hack Member
    Ontario, Canada
    Looks great!!!
  15. hammerheadx
    hammerheadx Member
    Binghamton, NY
    I like the color.
    Very meticulous. A man after my own heart.
    Nice work!
  16. bigfitz52
    Very nice indeed Carl. Fine job; from your list it looks like you've covered everything.
    Now all you have to do is ride it and see what sort of unexpected surprises it has in store for you.
  17. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Truly a beautiful restoration. Enjoy the ride and be proud.
    BigFitz posted a couple weeks ago that often gets approached by people who notice how great his bikes look.
    I would plan on allowing extra time when you go to the store in order to answer their questions.
    Enjoy!
  18. Tman_74
    Tman_74 Member
    North Ridgeville, OH
    Nice Job!!!! LOOKS AWESOME!!! Be proud and safe!!!! Now Ride it!!!!
  19. cturek
    cturek Member
    O'Fallon, MO
    Thanks everyone for the kind comments. I'll be getting a plate for it this week and can start putting some real miles on it.
    I did take it out yesterday for about 10 minutes just around the neighborhood. It sputters just a little taking off from idle, but runs very smooth after that. It holds a steady speed very nice and accelerates without hesitation. The clutch works good, no slippage. It shifts and pulls thru all the gears which was a big relief as I had no idea about the condition of the transmission. While in third gear, I opened it up and WOW!! It took off like a bullet shot from a gun. Much more than my old 350 Honda did!
    Working on the bike this past year was very enjoyable and I could not have done it without the resources on this forum. The sense of accomplishment of doing the work yourself does feel very good. Thanks again everyone.
  20. 550FAN
    550FAN Member
    Minnesota
    Looks beautiful, nice job
  21. 550FAN
    550FAN Member
    Minnesota
  22. 550FAN
    550FAN Member
    Minnesota
    Did you have the Carbs synchronized, maybe the sputtering problem
  23. tennsouthernbelle
    tennsouthernbelle Member
    Morristown, TN
    ooooo pretty.
    I have the same color bike. I also like the seam trim on the tank. I think I'll do that to mine.
  24. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    VERY nice indeed!! what did you use to get you plastic parts so dark and looking like new?
    you get 3 attaboys for that one ! :D
  25. cturek
    cturek Member
    O'Fallon, MO
    Mothers Back to Black. Works real good.
  26. shangovi
    shangovi Member
    Burtonsville MD
    one word WOW! 8O
    luv the paint job (correction) luv everything. Great work.
  27. technonerd7
    technonerd7 Member
    Orem, UT
    Very very nice. What a beatuiful color that bike is.
