Neck Bearings, Progressive Fork Springs "82 XJ Seca Turbo
Discussion in 'XJ Modifications' started by turbonator, Sep 19, 2006.
  1. turbonator
    turbonator New Member
    Calgary, Alberta, Canada
    :D I'm looking for feedback on neck bearing set for 82 Seca Turbo...Roller Bearings, does anyone have bearing Numbers to avoid high cost of cycle supplied...bearing shops are MUCH Cheaper!!! In addition I have progressive fork springs for said unit...does anyone have personal experience re:SPACERS oil and oil volume for same???
  2. Robert
    Welcome to you. I'm not a turbo type so I'm just going to greet you and let you know that one of our Whizzers will be along shortly to address your issues. See you on the forums!
  3. jasonlion54
    jasonlion54 Member
    Seattle, WA
    I put All Balls Racing tapered steering head bearings in mine. Don't know the specs, but they were about $50 from my favorite bike shop.
  4. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    Re: Neck Bearings, Progressive Fork Springs "82 XJ Seca Turb
    Progressive springs require a 1.5" spacer after they are installed, which can be cut quite quickly and accurately from the stock spacer with a cheap pipe cutter. The stock oil amount for the forks is 238cc. The new springs are thicker than the old, so about 10% less oil is required. I just put in 200cc per leg and called it a day. I felt the front end was a bit too slack still, so I put in the longer length of the original spacers. I am now a bit oversprung, but MILES better than stock. I have a set of taper bearings here for it as well which I bought off of partsnmore. Turns out, the bike had tapered bearings in it already, so I didn't put them in. I'd like to find a good Telefix fork brace to steady up the front end though. By far the best mod for the front end was a set of braided brake lines and an aftermarket XS1100 brake master cylinder from PartsNMore. Not a cheap mod, but well worth it. One finger braking if I feel so inclined.
  5. HooNz
    HooNz Member
    You've probably listed it somewhere but what ia your bike MacMcMacmac?
    in signiture....
  6. turbonator
    Thanks for the tips on Progressive springs...I take it that perhaps a 1" Spacer might be ideal??? As for the neck bearings I got the All Balls set, and I will post the bearing I.D. #'s ASAP....In addition I have acquired the very difficult to find right muffler for an '82 Seca Turbo, but its missing the end cap(!!!!????) If anyone has same I'd sure like to acquire it.
  7. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    1" spacer would be shorter than what's called for, leaving you with a softer front end. Mine is currently around 2", and a bit too stiff.
