stearing head bearing
Discussion in 'XJ Modifications' started by fatman123, Sep 2, 2009.
  1. fatman123
    fatman123 Member
    Winnipeg MB Canada
    I just removed my steering head bearing off a 81 750r seca. The upper and lower ball bearing cups came out with two hits with a punch. I've read on the site that the race are something of a problem to get out. Am i missing something or did I just have good luck. Holding off instaling the new tappered bearing until I get some feed back incase I left something inside. dont think i did though. Finaly some good luck with this bike.
  2. Hillsy
    Hillsy Member
    Ball bearing races are far easier to remove than tapered bearing cups in most cases. And it should be pretty obvious that you've removed everything from the headstock.
    Looks like you got lucky - nice one :wink:
  3. fatman123
    fatman123 Member
    Winnipeg MB Canada
    hope so. yeah i dont think there is anything left but no experince with bikes and thought i check. the top race sits a little proud, is that normal? cant seem to drive it in any farther.
  4. Hillsy
    Hillsy Member
    I think it does sit a bit proud - read a post on here the other day saying that (??)
  5. fatman123
    fatman123 Member
    Winnipeg MB Canada
    I havent seen on here. but this months motorcycle classics mag shows them building a cb cafe and the picture of there upper race on the new tappered bearing looks just like mine, sits proud. they say its supposed to on the honda i guesse its the same on the xj.
  6. fatman123
    fatman123 Member
    Winnipeg MB Canada
    oh by the way. Iused a $15 dollar bicycle spanner to remove the bearing collar. great idea that i got off this site.
  7. fatman123
    fatman123 Member
    Winnipeg MB Canada
    just keeping the thread alive. anyone have any thougths what else i should watch out for or keep in mind while i put it back together. will be finishing on friday to nice today going golfing.
  8. Hillsy
    Hillsy Member
    Make sure you assemble the entire front end before you torque the fork pinch bolts and top clamp nut. The front gaurd acts as a fork brace and if you fully tighten the top clamp / forks before you fit the front wheel and gaurd you may run into alignment problems (IE the forks may not be straight in the clamps).
    Take your time and double check all the bolts (especially the caliper).
  9. joshua
    joshua Member
    Lake Worth
    About to rip apart my own front end and do all this stuff,head bearing,fork rebuild,new springs,and seals,possibly the anti-dive unit while i got it all apart,caliper rebuild and master cylinder rebuild and am wondering about what hillsy said. its a bit fuzzy in the brain cells mind if ya elaborate a bit?
