WHOA! I gotta get me one of THESE!
Discussion in 'XJ Technical Chat' started by bigfitz52, Sep 25, 2009.
  1. bigfitz52
    Just because, if for no other valid reason: http://www.carbtune.co.uk/microturn.html
    It will actually come in handier setting the Norton's ignition timing than it will trying to use it on my XJs carbs; but who cares?
    It's bloody COOL!
  2. Ltdave
    Ltdave Member
    in not just for the Cool Factor!
    so, is it bloody cool because its A) from gb or B) because you need one for your Norton???? lol....
  3. RickCoMatic
    They ought to send me one of those baby's for free!
    I've been trying to let everybody know that the Edge they want to tune too is within the thickness of a Dime or a Nickel.
    This tool gets down to 1/2000 of an inch.
  4. alexdc03
    alexdc03 Member
    I have a carbtune, works flawless.
  5. Lou627
    Lou627 Member
    Queens, NY
    Rick, you were the first thing that popped into my mind when I saw this
  6. CJ06XLT
    CJ06XLT Member
    Southwick, MA
    That things pretty cool. You could buy a cheapo 2-3 mic, cut off the stationary side, and grind down the end. I'm not sure it would be any cheaper though.
  7. Polock
    that may very well be the stupidest thing i've ever seen
  8. TIMEtoRIDE
    Unless held in a fixture, it introduces several degrees of inaccuracy by holding the housing by hand. It's a toy, like a scope on a pool stick.
  9. RickCoMatic
    I don't know what the smallest increment is I have ever "Tweaked" a Pilot Mixture Screw; but I'm sure it was considerably more than 1/2000.
    I'm not sure that even the smallest Tweak would be that small.
    That "Tool" is for REAL, right, ... not a "Gag" somebody made-up!
  10. bigfitz52
    Very true. You gotta admit it's cool though-- in concept.
    Rick, yes, it's for real; the Carbtune/ColorTune folks are offering it.
  11. Polock
    heres the phillips model with digital readout
  12. bigfitz52
    I think you had it right the first time.
    However, maybe it uses GPS so that the movement of your other hand wouldn't affect the reading...
    I just knew Rick would want one.
  13. Polock
    this is what i use, i got them on ebay from some guy named Harry
  14. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    LOL! Polock you never cease to geek me out
