oil recomedations
Discussion in 'XJ Technical Chat' started by jcboyd, Sep 26, 2009.
  1. jcboyd
    jcboyd Member
    Dickinson, Texas
    what kind of oil and how much should I put into my 1983 xj 750
  2. schooter
    here are the favorites:
    Casterol GTX 20w-40 & 20w-50
    Also, shell rotella 15w-40, Which i bought to try
    as for how much, look at your gauge... usually 4 qts...
  3. schooter
    also, make sure it has no additives!!! those can wreak havoc on our clutches, making it slip like crazy
  4. SQLGuy
    SQLGuy Well-Known Member
    I'm using the Amsoil 10W40 motorcycle oil in my '82. I like the high heat handling of these oils. I switched from Castrol GTX after seeing the 300+ degree oil temps I was hitting on the dyno.
  5. jcboyd
    jcboyd Member
    Dickinson, Texas
    thanks guys.
    just bought the bike last week.
    waiting on manual to get all my p.m. work done.
    doin oil change this weekend.
  6. TIMEtoRIDE
    Just shy of 3 quarts. Look at the glass window near your right ankle.
    Overfill a little to see a small bubble at the top. That way, you can see if your carbs spew gas into your crank case. The small bubble goes away.
  7. kenosobby
    kenosobby New Member
    Rotella-T Synthetic is my weapon of choice for pretty much everything i own...atvs, sportbikes, lawnmower..never had a lick of problems.
  8. wamaxim
    wamaxim Active Member
    Vancouver, USA
    I would recommend Castrol 20W50 4T. It is specially formulated for motorcycles and is readily available. I use it in my Maxim and in my water cooled K1200LT Beemer as it meets all the requirements for both bikes.
    There is much comment about using automotive oils but they don't meet BMW's or Yamaha's API designations.
    Loren
  9. littlegiant
    littlegiant Member
    Toronto, Canada
    Not to forget, Leave the bike on Centre stand to check the oil window.
  10. backblast
    backblast New Member
    Louisiana
    Just try to find a oil with good Zinc in it. Oils nowdays really lack the stuff, and our old school cams in older engines have really felt the effects of the new emission regulations. Rotella is my prefered choice has around 1200 ppm very good compared to some other shelf oils.
  11. RickCoMatic
    In everything I have or owned got Castrol 20W~50.
    Never had a Clutch, Gear, Starter Clutch or Chain Guide problem.
    It's rated as a Racing Oil and the XJ-Engine deserves Racing Oil.
  12. wamaxim
    Vancouver, USA
    Loren
  13. dwcopple
    dwcopple Active Member
    bay city, michigan
    Valvoline VR1 20w50 or ANY diesel 15w40 for me
  14. jcboyd
    jcboyd Member
    Dickinson, Texas
    Thanks everyone for the input.
    it has been helpful.
  15. plantingchickens
    plantingchickens New Member
    I know this sounds odd, mainly cause i don't know what the brand is a knock off of... But I have always used 20/50 Wal-Mart oil. I have never had a single problem with it on my Maxim 650, and I ride probably about 300+ miles a week rain or shine. Plus its the cheapest oil around.
    I have also used the same oil in my '69 VW bug, and my old '86 Honda Rebel.
    And if you don't like wal-mart, you can generally enter through the side door where the lube tech area is (the only time I ever go there is for oil haha)
    Also for completely unrelated to XJ laughs, go to www.peopleofwalmart.com :lol:
    -Twiggie
