mirror issues
Discussion in 'XJ Technical Chat' started by Ltdave, Sep 2, 2007.
  1. Ltdave
    Ltdave Member
    A) do the 'nuts' on the ends of the mirror rods spin independantly of the rods themselves?
    B) any ideas short of risking the brake fluid resevoir for removing the righ hand mirror rod?
    ive sprayed an awful lot of liquid wrench on it to no avail....
    thanks
    d
  2. Nick
    Nick Member
    Vernon, BC Canada
    A) Yes
    B) Are you aware that one of the mirrors has left hand threads (sorry, can't remember which one)
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    The left hand theaded nut is marked with a notch all around the locking nut.
  4. MiCarl
    LH thread is on the RH mirror. So, the one on the MC mount is LH.
    I think the idea is to have the stalk loosen rather than breaking the mirror if you bump something.
  5. Ltdave
    Ltdave Member
    B) no i did NOT know that...
    thanks. i will try it...
    d
  6. Energi2er
    Energi2er Member
    Northwest
    Me either.. I've been riding with no right mirror because It came off, and I tried to put it back on and couldnt figgure out why it wouldnt start threading. Duhh, I didnt even think to try it LH. I read this thread and went out and tried it.. Now I have a right mirror again.. THANK YOU......
  7. Ltdave
    Ltdave Member
    YAHOO.
    got the right had mirror stalk off the bike and can now clean it up to match the left...
    who would have thunk that it had left handed threads. reminds me of the time i was rebuilding a WWII GMC deuce and a half. i was attempting to remove the left hand wheels. i tried the 4-way, i went back into the shop and got a 2' breaker bar and socket. that wore me out so i went back in and got a 2' length of pipe. the guy i was working with gave me a sideways glance...
    the pipe didnt work (yes i had soaked it with a can of s'ok a citrus based rust penetrant) so i went back in and cut new piece of pipe about 6' long. when i started walking out the guy asked where i was going with the pipe. i told him to take the da_ned lug nuts off. he, calm as an old guy sitting in a rocking chair with a pipe asked "are you turning them the right direction?" i about lost it and said, "i KNOW how to take lug nuts off." he replied "your thinking righty-tighty, lefty loosey arent you' and gave a chuckle. he said try them the other way...
    sure enough they were so easy to take off the 'wrong way' that i could have almost done them by hand... :oops:
    d
  8. eman1974
    eman1974 Member
    Halifax, NS, Canada
    Reserecting this thread to see if someone can clarify. My right hand mirror needs to come off. I see 2 nuts here. I assume I only want to turn the top one - and I want to turn it clockwise (right) to loosen it? Lefty-tighty Right-loosey?
  9. MiCarl
    That's just one nut. The line in it is to let you know it is left hand so yes, righty-loosey for this one.
  10. bigfitz52
    +1.
    "The line" (quite often just "notches" on the flats) is a universal indication of LH thread; you'll find these other places than just Yamaha mirror stalks.
  11. eman1974
    eman1974 Member
    Halifax, NS, Canada
    wow, I reaally am a mechanical dunce. Learn somthing new every day.
  12. johntc
    johntc Member
    South Dakota
    Nah, you're not a dunce. A dunce is someone who refuses to learn something new every day.
    If you don't learn from other peoples mistakes you'll have to make them all yourself.
  13. mwhite74
    mwhite74 Member
    No notch in the nut on the right hand mirror on mine. Either way thanks for the tip guys, you've saved me some embarrassment ;)
  14. bigfitz52
    REALLY? Sometimes they're just "nicks" in the corners of the flats and not a line all the way around... I've never seen a reverse-threaded nut that wasn't marked somehow.
