Concidering buying 550 Maxim... have a couple of questions!
Discussion in 'XJ Technical Chat' started by SSRat, Dec 15, 2009.
  1. SSRat
    SSRat Member
    Is the frame on the Maxim's the same as the Seca's?
    Also, does anyone know what other bikes triple trees (if any) would bolt up to it?
  2. schooter
    yes, and alot actually, fz600 is a good example
  3. SSRat
    SSRat Member
  4. schooter
    but thinking again im not 100% sure it is the same frame as maxim, its close at least... but im like 80% sure it is
  5. schooter
    eww thqt bike doesnt look pretty... offer 50 bucks
  6. bigfitz52
    Guys; The frames on the 550 Seca and 550 Maxim are COMPLETELY different. They're a different SHAPE.
    I don't know about the whole fork assembly but I do know they have different diameter front fork tubes.
    Although subtle, there are a lot of differences between the 550 Seca and Maxim; beyond the obvious like the rear brake-- cams for instance.
  7. schooter
    oh whoops
  8. nsosh5
    nsosh5 Member
    oklahoma
    Yeah I bought my bike complete with everything for 200 bucks all it needed was a carb clean tires and breaks.
  9. SSRat
    SSRat Member
    Well in further talking with the guy it seems it's needing alot of little things. I don't mind making a new wiring harness, and hell I would probably do it anyways... but not having any of the things that PLUG into the wiring harness kinda sucks... (ignition control, sensors, saftey switches etc) so no go on this one.
  10. bigfitz52
    It shouldn't take too much poking about for you to find a complete one for cheap. That thing's not even worth anything as a parts bike.
