seca on 2 cylinders...
Discussion in 'XJ Technical Chat' started by secaman, Jan 4, 2010.
  1. secaman
    secaman Member
    guatemala, central america
    8O ok im back,
    my seca been sitting in the garage for months!
    it runs only on 2 cylinders,
    the 2 inner ones work fine.
    any ideas?
    ill start testing coils etc,
    let uall know how it goes!
  2. Hillsy
    Hillsy Member
    Coils are 1-4 and 2-3, so it looks like your 1-4 coil might be the culprit. Check spark first, if none, then work your way back to the coil and further if necessarly....
  3. stereomind
    stereomind Active Member
    Tulsa, OK
    Corroded TCI terminals could keep one or both coils from firing, so it may not be a bad idea to check them.
    Any difference whether the choke is on or not?
  4. secaman
    secaman Member
    yes it only start with choke,
    barely idles,
    and seems fine in high revs.
    could a sulfated battry be the problem?
    im starting it with a booster,
    battery is dead!
    i will check terminals today...
  5. secaman
    secaman Member
    ok i found aproblem,
    the 8 conect coming form the reg/rec is burned,
    could this be the spark problem?
    or this is why my headlamp burns?
    it is burned in the re/white wires.
    ill try show some pics later
  6. Hillsy
    Hillsy Member
    Check the voltage at the battery when the bike is running - you should have between 13.5 to 14.5v. Anything over 15v indicates a faulty reg/rec (or bad earth) and yes you will fry batteries, headlights, etc.
    If the voltage does not increase from static, then the stator is faulty or connector is shot (you'll want to replace the connector anyway).
    Runs OK at higer revs? Could be blocked pilot circuit in carbs, or coil on the way out. Check coil resistances and all other ignition related connectors. If that checks out, clean your carbs.
  7. RickCoMatic
    If your Bike was running; but then SAT for some length of time, without the Carb Drain Screws removed and the Battery on a Tender ... you could have more than one or two problems.
    You may need to do a few things.
    Carbs.
    Battery
    Brushes
    Coils
    You'll have to Test and inspect everything on the list.
    If you still have a STOCK Fuse Panel ... that needs to be replaced too.
  8. schooter
    hokey smokes! I gotta say, WOW
    you're an older member than RickCoMatic
    been here since 05
    snap
  9. secaman
    secaman Member
    ye lol, the seca been sitting a while...
    ok i found the cylinders 1 n' 4 arent firing,
    so i bought a used coil, my question is,
    what side goes to the 4 and which to the one?
    the old ones were numbered, or it dont matter?
  10. stereomind
    Tulsa, OK
    Don't matter -- they fire at the same time.
  11. bigfitz52
    to expand on that a bit; these bikes fire the coils every time the pistons come up so there's a "wasted spark" on the exhaust stroke, which is why it doesn't matter.
  12. secaman
    secaman Member
    ok i thought so, just wanted toma ke sure.
    and the bike works now, today i go for a test drive!
    keep yall updated.
  13. secaman
    secaman Member
    ok bike works fine!!
    after sitting for more than ayear for "carburetor problems",
    turns out it was the coils! ;)
    ok ty for ur h elp guys!
