LED Flasher unit problem...geek advice sought!
Discussion in 'XJ Technical Chat' started by adrian1, Jan 6, 2010.
  1. adrian1
    adrian1 Active Member
    The bike - 1987 XJ 900.
    I bought some LED indicators recently as well as a new electronic flasher unit. It has the right number of pins - 3. When I plug it in though, I get no light at all from the indicators. The std flasher unit has the fol letters - Centre = L, Left hand = C and right hand pin = B (this is looking at the pins face on)
    The new unit has the fol Centre = L, Left Hand = E, Right Hand = B.
    I presume the centre pin is the earth? What do I need to do to get it working please?
  2. dwatson636
    dwatson636 Member
    Laveen AZ.
    What is the flasher make and model number?
  3. Lou627
    Lou627 Member
    Queens, NY
  4. lopezfr2
    lopezfr2 Member
    Point Loma, San Diego, CA
  5. dwatson636
    dwatson636 Member
    Laveen AZ.
    I used the Triton EL-12 2 prong electronic flasher. Pep boys $8.99. direct replacement. Matched the L to the L pin and it worked straight away.
  6. adrian1
    Thanks for the replies guys...sorry forgot to mention I live in OZ (must get that profile fixed!)
    I was hoping to modify the unit I have rather than buy another....
    Mt watson, here is the unit I bought
    http://cgi.ebay.com.au/3-Pin-Electronic ... 04001r2414
    The picture also shows the prong identification and voltages which may give potential posters a clue?
  7. RickCoMatic
    Look at the Web Site for the Company called:
    Signal Dynamics
    They have a great many Products and solutions to Motorcycle Signal and Flashing situations.
    I got their Module called: Back-Off
    This module flashes a trio of Red LED Strips 5 Times before having them come-on Full ... each time the Break Lights come-on ... and as often and as quickly as you can work the lever to make the Break Lights flash.
  8. adrian1
    Thanks Rick. Up early (or late) eh?
    Hope you're coping with that snow over there! 37 degrees C here today :)
  9. dwatson636
    dwatson636 Member
    Laveen AZ.
    Try this wiring setup. Found elsewhere in another forum.
    The wire colors go to the prongs as follows:
    X ----> Br (brown)
    P ----> G/Y (yellow w/ green stripe)
    l -----> Br/W (brown w/ white stripe)
  10. adrian1
    Thanks Mr Watson but not sure how that helps? The letters X, P, and l are not meaningful to me....
    Can you elaborate on where those letters are found (looking down upon the three pins). I need to know the purpose of each wire...ie which is the earth etc....
    Original Quote:
    "The std (original)flasher unit has the fol letters - Centre = L, Left hand = C and right hand pin = B (this is looking at the pins face on)
    I presume the centre pin is the earth? What do I need to do to get it working please?"
  11. adrian1
    For the record B = battery, L = Load and E = Earth
