Levers same material??
Discussion in 'XJ Modifications' started by kcoop99, Feb 17, 2010.
  1. kcoop99
    kcoop99 Member
    BFE, Nebraska
    I am in the process of polishing EVERYTHING on my bike. I took off the clutch lever and brake lever. I sprayed them down with aircraft stripper and while the clutch levers black finish just came right off while the brake seemed to be different? Thoughts? Thanks!
  2. razz1969
    razz1969 Active Member
    Cleveland, Tx
    The fact that you actually got the finish off of the one is amazing since it is a plastic coating. But to answer your question, the reason that you could get the coating off the one is probably the PO broke or bent the original one and painted the replacement to match the other. Bravo on the polishing, I love making dull metal come alive with sparkle and shine.
  3. Altus
    Altus Active Member
    London, Ontario
    Well - all that work seems like a bit much, when you can get brand new chrome plated ones for $20
    Don't know if Chacal has the silver/polished ones, but Mike's XS has them for $10 each
    Mike's XS
    Scroll down to Part #08-0117 & Part #08-0131
  4. kcoop99
    kcoop99 Member
    BFE, Nebraska
    Wait til you guys see this bike when I am done. EVERY aluminum part is being polished! And with that aircraft stripper, there is nothing that can hold up...well, until I got to this part.
