81-83 Seca 750 touring package fairing and trunk $200. obo
Discussion in 'For Sale, Trade/Swap, Wanted' started by JayEye, Feb 18, 2010.
  1. JayEye
    JayEye Member
    Chicago Heights, Il
    I have a gun metal gray front fairing that has all of it's parts, full size windscreen, both compartment doors, pouches, key and front mount hardware. The headlight adjustment works great, working cigarette lighter. It has all the mounting to connect it to you bike, but you will need two 10mm x 1.25mm 1 1/2 inch long bolts, flat & lock washers, two 8mm or 7mm bolts & washers, you will also need to installl your turn signals on the mounting bracket.
    Now for the bad.... the front headlight cover glass broke (not the headlamp itself) so I molded and installed a piece of lexon glass that works great. The fairing has a few medium scratches that has been touched up with non color match paint, and it has a superficial crack in one of the plastic mounting tab that can be fixed with a little epoxy if u want.
    The trunk, it is in good condition some scratches and lights were mounted to it in the past. The back rest is in good shape the lid is stong but with sratches on top, the seal in fair to good shape it doesn't let water in. On the left side of the box the clear coat is missing a section about 3" x 3" I would say, also the locking latch works good.
    Now the bad.... I do NOT have any of the mounting to go with the rear trunk. You will have to search for it or if you are handy fabricate mounting hardware for it.
    I'm selling both pieces together and I'm asking $200. O.B.O. for both of them. I have pictures but for some reason I could not up load them to this post. Look in my photo gallery they can be viewed there.
  2. JayEye
    JayEye Member
    Chicago Heights, Il
    Re: 81-83 Seca 750 touring package fairing and trunk $200. o
    If anyone is interested shoot me a reasonable offer.
  3. Great_Buffalo
    Great_Buffalo Member
    43.719908/-98.030276
    Why are you parting this stuff out? Did something happen to your bike?
  4. JayEye
    JayEye Member
    Chicago Heights, Il
    I wanted side cases, when I found them locally the seller would not separate the cases from the rest of the touring package he was selling. I bought everything and now I'm selling off the extras.
  5. Great_Buffalo
  6. BRSM
    BRSM New Member
    I want the lower fairings (the one's that are adjacent to the front/main fairing) but not the main fairing!!
    How much?
  7. BRSM
    BRSM New Member
    Let me know if you decide to separate the windscreen from the fairing. I would be interested in it as well.
  8. JayEye
    JayEye Member
    Chicago Heights, Il
    Thank you everyone for the interest in these items, they have been sold.
