Xj 650 Turbo - pressure sensor - make a reading
Discussion in 'XJ Technical Chat' started by pirok, Mar 24, 2010.
  1. pirok
    pirok Member
    Aarhus, Denmark
    Well I tried to see if the pressure sensor were within specs. The reading on the voltage meter said 3.9 volts but it should be about 2 volts i think.
    Someone who had any experience with that? Is the sensor dead? It do though react when I blow in it. (the reading gets higher)
  2. pirok
    pirok Member
    Aarhus, Denmark
    Re: Xj 650 Turbo - pressure sensor - make a reading?
    Anyone who could make a reading on a running XJ Turbo?
    You just make the reading from the R/W wire comming from the pressure sensor to ground (-), when the ignition is ON.
    (+ on the meter to the R/W wire and - to ground)
