Well, I changed my head gasket, but now.........
Discussion in 'XJ Technical Chat' started by midknightrider83, Jun 7, 2010.
  1. midknightrider83
    midknightrider83 Member
    Houma, LA
    I have almost no power at high rpms, or when I take off in first. After changing the gasket I re-colortuned the bike. Idles great, hell, better than ever, but now from 1100 to 2000 rpms and from 6000 and up it feels so.... sluggish. Really its over the entire rpm scale, but thats when its most noticeable. The carbs were cleaned and synced before i changed the gasket, and the bike is completely stock. I tried to search the forums and found nothing. Please XJ bros. HELP ME!!!!!
  2. cutlass79500
    lawrenceville georgia
    i know its a pain but check your timing again could be off a tooth or two.
  3. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    Have you checked the compression since changing the gasket?
    While the head was off, did you lap the valves? Check the clearance??
  4. midknightrider83
    Houma, LA
    I didn't check compression, valves, or clearance. I'll recheck the timing tomorrow and get back to yall. I'd do it tonight, but all my tools are at work.
  5. davstarks
    davstarks Member
    Grayling MI
    Ya, timing may be it, 1 tooth off is hard to tell. But when its dead on it's obvious. (If that makes sense)
  6. midknightrider83
    Houma, LA
    Prolly Hard to tell, but from the symptoms, with is the more likely culprit, exhaust, or intake?
  7. midknightrider83
    Houma, LA
    Rode my bike to go get some cigs. And everything seems fine now. I'm Gonna ride it tomorrow and make sure. Maybe i'm just paranoid. Oh well, good night fellas.
  8. day7a1
    day7a1 Member
    San Diego, CA
    Maybe you were just having nicotine cravings the whole time?
