air jets question
Discussion in 'XJ Technical Chat' started by xj650jeff, Jun 6, 2010.
  1. xj650jeff
    xj650jeff New Member
    Hi all from MN,
    I goofed on my first carb dismantle/clean and didn't note which air get goes where before I had all of them taken out :x . I would assume the one with the larger hole would go on the air intake side of the carb since it would then be above the main jet.
    Anyone remember?
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    The pilot air jets are larger, and go towards the front.
    The pilot FUEL jets are smaller, and also go towards the front.
    hope that helps....
    EDIT: you should put your bike's year and model in your signature, so we don't have to guess :mrgreen:
  3. xj650jeff
    That does help, thanks!
  4. xj650jeff
    Actually, the pic in my Haynes manual has the pilot air jet in the back (air box side) and the main air jet in front (engine side). Am I safe in assuming the main air jet would have the larger opening?
  5. chacal
    No, the main AIR jet has a smaller opening than the pilot air jet..........exactly opposite of the size relationship between the FUEL jets.
  6. RickCoMatic
    Here's a Visual Aid:
    The AIR Jets are OPPOSITE of FUEL Jets:
    Main Air Jet = (o)
    Main Fuel Jet = (O)
    Pilot Air Jet = (O)
    Pilot Fuel Jet = (o)
  7. xj650jeff
    Perfect! Thank you guys so much!
