beef'n up displacement!!!??
Discussion in 'XJ Modifications' started by 209SECA, Jun 14, 2010.
  1. 209SECA
    209SECA Member
    MANTECA CA
    Will xj750 cylender and pistons fit an XJ650 case? Is this the only difference between the 650 and 750?
  2. nkavanau
    nkavanau Member
    Vancouver BC
    Here are a couple of side by sides. Both 81's. The 750's bore is 2 mm greater. Aslo a totally different stroke, so different crank. Think you would be out of luck.
    Of course, without the particulars on the 2 engines, I couldn't say with any certainty, but highly doubt they would be interchangable.
    Make Model Yamaha XJ 650 Maxim
    Year 1981
    Engine Air-cooled four stroke, transverse four cylinder, DOHC, 2 valves per cylinder,
    Capacity 653
    Bore x Stroke 63 Ñ… 52.4 mm
    Model Yamaha XJ 750 Seca
    Year 1981
    Engine Air cooled, four stroke, transverse four cylinder, DOHC, 2 valves per cylinder.
    Capacity 749
    Bore x Stroke 65 Ñ… 56.4 mm
  3. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Too bad you don't live closer. I have an entire 750 Maxim engine you could have just for picking it up. Free!! I don't know the history of the engine or the miles (got it for a parts bike)
