Hopefully my last topic about this...
Discussion in 'XJ Technical Chat' started by codydenver, Jun 22, 2010.
  1. codydenver
    codydenver New Member
    MN
    Thank you for everyones help so far. Here's where I stand. 82 xj650. the bike ran fine when I took it a part... It's wired correctly and the safes are in the right spot because I never touched them. The battery is full charge. I turn on the key and the oil light comes on (like normal) It's in neutral, but the neutral light does not come on. (the light works when I hook it up to a power source, so it;s not the bulb) when I pull in the clutch, i can hear a clicking sound (so I'm assuming the clutch system works). then I push the start bottom, the oil light dims until I let out the button. no start.. no sounds...
  2. MiCarl
    Oil light should not come on until you push the start button. You're either low on oil or wired incorrectly.
    Neutral switch grounds the neutral light circuit. If you're getting it to light by putting + to it it's not getting power from the ignition switch.
  3. codydenver
    MN
    there is no oil in it. I just need to hear it turn over so I can start fabrication. It's not in a position to ride, just need to get it wired first. yes for whatever reason then, the oil light has always come on with the key? then shuts off with pressure.
  4. MiCarl
    It's not an oil pressure sender, it's an oil level switch. It completes the circuit if there is too little oil in the pan.
    The start button also completes the oil level circuit as a lamp test.
  5. BlackMax
    BlackMax Member
    Brampton Ontario
    sounds like the starter relay is sticking........
  6. RickCoMatic
    If you have a POWER Relay
    Plugged-in to the Wiring Harness
    where the SAFETY Relay
    Belongs ... the "OK TO Start" Signals
    get all screwed-up.
    Remove the Relay you have in the position where the SAFETY Relay belongs.
    When the RELAY is removed, ...
    The Bike should Start with the Transmission in NEUTRAL.
    If the Bike does NOT Start ...
    TEST the NEUTRAL Switch
    For power In, and On / Off ... when the Trans is in Neutral or in gear.
    Test the CLUTCH Switch.
    Unplugged
    Plugged-in
    For power On / Off when the Lever is Pullled
    Look to see that the Wiring for the Clutch Switch did not get pinched and grounded anywhere between the Switch and the Quick-Connect.
    Use a 9 Volt Battery and TEST the RELAYS are Opening and Closing.
  7. codydenver
    MN
    I think it's the neutral switch... got one on the way.. we'll see
  8. codydenver
    MN
    /..\ so your saying IF I PUT OIL IN IT!? IT MIGHT SOLVE THE PROBLEM!? GKD DMNA IT ALL... I swear if that is all I'm going to throw it out a window. lol with my super Hulk strength!
