Replacing Fuse Box With New Glass One
Discussion in 'XJ Technical Chat' started by Deathalo, Jul 6, 2010.
  1. Deathalo
    Deathalo Member
    Raleigh, NC
    Hi all, I know XJ fuse boxes are a major headache, and a lot of you have opted to switch them out for newer plastic fuses. I need to swap mine out of my 82' 550 because one of the wings is broken off and the fuse is currently being held by electrical tape. Thing is, I don't really want to modify much to get a plastic replacement.
    So, I found this online: http://cgi.ebay.com/ebaymotors/XS-XJ-FZ-Fuse-box-replacement-Yamaha-XS1100-XS11-XS650-_W0QQcmdZViewItemQQhashZitem35a9da79efQQitemZ230482934255QQptZMotorcyclesQ5fPartsQ5fAccessories
    You think this will work fine for my bike, I don't think I'll have any problems as I always keep my bike under cover and take care of her.
    -DH
  2. bigfitz52
    Why not just fix the existing one then? (Replacement clips from Radio Shack.)
    I would still recommed upgrading to a modern "blade type" fusebox though.
  3. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    My 1982 XJ750J Maxim has the same wire configuration......
    Rick-o-Matic,
    In my earlier post, that is the way I have it wired to the new fuseblock....
  4. Deathalo
    Deathalo Member
    Raleigh, NC
    I took your advice and bought the fuse holders from Radio Shack and pried off the metal parts, which fit nicely where the old ones did. Now to solder on the wires.
  5. bigfitz52
    Solder on the wire with the clip OUT, make sure the wire is in the position it's going to end up. Slip into place once cooled down. Otherwise you'll melt plastic.
  6. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    also, for anyone putting in a blade style box, be sure to get the large style. I made the mistake of doing the mini blade fuses and then noticed that I have NEVER seen these fuses available at a 7-11 in the middle of the night. Luckily I carry a fist full of spares.
  7. cheezy66
    cheezy66 New Member
    northern wisconsin
    go to xs11.com look up a gent named topcat. he sells a fantastic blade style replacement box for cheap. i used it on my xs1100. this is the way to go. he includes the crimp connectors.
  8. Deathalo
    Deathalo Member
    Raleigh, NC
    The newly soldered clips work wonderfully, only thing was, I needed a 10 amp fuse and couldn't find one ANYWHERE. Radioshack; nothing, advance auto; zip. I finally looked up the type (AGX 10A are the ones!) and found them through Grainger, called em up and they shipped a 5 pack to my local store in a day, picked em up for less than 5 bucks. It's a good thing I have a spare 20A still and now 4 spare 10s cause hell if I'll be able to find these again locally.
  9. BillB
    BillB Active Member
    Tulsa Oklahoma
    I broke a blade ad zip tied it to get me home.
    Never fixed it.
  10. bigfitz52
    GRAINGER! WTH didn't I think of that. Thank you.
  11. Deathalo
    Deathalo Member
    Raleigh, NC
    lol you are welcome :D
