Stator rectifer questions
Discussion in 'XJ Technical Chat' started by dwmauney, Jul 29, 2010.
  1. dwmauney
    dwmauney New Member
    Delray Beach Fl
    What are the 2 wires ( red and green ) for on the stator cover. The ine was cut when I took the cover off?
    Where is the brown wire supposed to go comming off the rectifer?
    Rebuilt, cleaned, jetted my carb many times to get it right.
    New batrery
    Had it running. But after a few trips it will not start again. Turns over but will not fire. Will not push start. it was running great though the idle was a little high. It will turn over but not fire. I have been looking it over. Replaced a few wires that looked bad now it will not get spar
    getting .7 ohm on the 3 white wires
    12.8 volts from the battery after trying to turn over a few times
    Any help would be great
  2. mlew
    What bike are you working on? I would guess that they are wires to the alternator brushes.
  3. dwmauney
    dwmauney New Member
    Delray Beach Fl
    Sorry it is a 1982 Xj 750 Maxim. Where are these wires supposed to go?
    Thanks for the quick reply
  4. dwmauney
    dwmauney New Member
    Delray Beach Fl
    here is a little more information
    4.8 ohm arcoss the copper strips on the stator. I just polished them clean. they were a little bit dirty but not burnt
    The brushes are 10 mm
  5. markie
    markie Member
    Suffolk, England
    I only have a 550 diagram but think most XJ Yamahas with brushes are like this.
    Brown and green go from the regulator to the rotor and there are 3 white wires that go to the stator. Red goes from the regulator/rectifier to the battery and a black to the chassis. The brown wire is also connected to the switched side of the ignition.
    Hope this helps.
  6. Maan
    Maan Member
    Karachi, Pakistan
    By brown going into the Switched side you mean it gets 12v current feed from the battery?
  7. markie
    markie Member
    Suffolk, England
    Maan: Yes, the regulator varies the excitation of the rotor dependant on the battery voltage. It uses a switched supply as you only want to excite the alternator when the bike is running.
  8. Maan
    Maan Member
    Karachi, Pakistan
    And what if the 12V feed is not connected to the Brown Wire attached with one of the brushes? Will the charging circuit work without it?
    Thanks Markie
  9. markie
    markie Member
    Suffolk, England
    No, it shouldn't. In the XJ550 service manual there is a section on this for testing the regulator.
    Be aware that some later XJ's (like my old XJ600) use a permanent magnet rotor and so DO NOT have the brown and green wires.
  10. Maan
    Maan Member
    Karachi, Pakistan
    Thanks once again Markie. :)
  11. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    I have an 83 XJ750 and the electrical system is the same. The red and green wires on the stator cover are connected to the brushes. One brush for each wire they then go to the TCI unit. Without them hooked up your charging system will no work.If the length of the brushes is 10mm they are at there minimum length and should be changed very soon.
  12. markie
    markie Member
    Suffolk, England
    Hey, hugger - don't forget to put some pics of your kettle in the gallery! (GT750). I had a GT550A - never had enough money for the 750!
