Looking for 1157 LED suggestions for Brake/Licence
Discussion in 'For Sale, Trade/Swap, Wanted' started by Metal_Bob, Aug 3, 2010.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Basically I'm looking at ebay an there are hundreds of 1157 LED Bulbs to choose from.
    I'm not sure which # of bulbs and/or pattern would be best for my 82 maxim that uses the running lights to also light up the plate.
    I'm looking at ebay because they are about 1/2 of sites like superbrightleds.com
    Sugggestions and links welcome :)
  2. serenmaster
    serenmaster Member
    deep woods
    http://www.customdynamics.com/summer_specials_2010.htm got a couple of things i like but i made my own one of the perks working for a sign company if you want to give it a try i could lead you on the right path in doing so not hard and much more costumable ~ is that a word?~ any how if you like i could sit down and type up a online parts an a step by step in doing so maybe even dig up a few vids on it
  3. Metal_Bob
    Bourbonnais, IL
    mis understanding?
    I need/want 1157 bulbs not custom stuff
  4. serenmaster
    serenmaster Member
    deep woods
  5. Metal_Bob
    Bourbonnais, IL
    Better link :) and the do have decent prices - have to check shipping cost... They just don't alot of LED configuration options... Maybe all the ones on ebay suck /shrug
  6. Metal_Bob
    Bourbonnais, IL
  7. mlew
    Have you tried a auto parts store. I got mine from AutoZone, 16 $ for two. My choice of red, white or amber.
  8. Metal_Bob
    Bourbonnais, IL
    I'll have to check again. Last time I saw one in stores it was like $16 for ONE (not sure what store).
  9. zap2504
    zap2504 Member
    Middletown, PA
    I have not seen an adequate 1157 LED replacement - mainly because the amount of LEDs you can put on an 1157 bulb socket is limited (in number, viewing direction and in lumen output). Also, LEDS generally shine in very limited viewing angles so if you are a little off-axis you may not see the tail/brakelight. The most impressive LED conversions I've seen were where a panel of LEDs were constructed to fit inside the tail light lens (and license illumination lens if needed). 40-50 LEDs in a panel will provide impressive lumens! Unfortunately, this almost always warrants custom creations (to fit around the specific internal mounting posts and other moldings). Not extremely difficult (I created a small one with 30 LEDs as a map light replacement inside my car) but not easy either.
