Erratic Idle
Discussion in 'XJ Technical Chat' started by Maan, Aug 3, 2010.
  1. Maan
    Maan Member
    Karachi, Pakistan
    I'm dealing with the infamous erratic idle problem, checked for vacuum leaks and found none yet the idle remains unstable, so i was wondering if the following 2 conditions can cause the idle to be the way it is.
    1. On the Carburetors of an XJ550 there are 3 Plugs where hoses/pipes could fit, the most middle one I know is for the petrol pipe from the tank. What are the other 2 for? and do they need to be plugged?
    2. I have 2 of the bikes Exhaust headers leaking, could they by any chance be contributing to the high idle problem?
    Thankyou.
  2. KrS14
    KrS14 Active Member
    St Marys, Ontario
    #2 YES! for sure that'll make you run lean.
    #1 you mean throughout the whole rack there's 3 plugs? As far as i can recall, there's the one for fuel. and that's it. Well, the bottom of the bowls have the drains i guess one each for 4, and there's only ONE fuel barb between carb #1 and #2.
  3. Maan
    Maan Member
    Karachi, Pakistan
    Kindly refer to the image attached. Between the 2 pointed arrows is the part I am talking about. I have 2 of these on both ends. Do they need to be plugged or do they remain the same as they are in the picture.
    Thanks for the previous answer. I have to get 2 of the manifolds tapped, will report back if that helps.
