First post - '83 XJ 550 new to me
Discussion in 'Hangout Lounge' started by cooleo, Sep 11, 2010.
  1. cooleo
    cooleo New Member
    Newbie to the forum!
    Picked up a " cleaning out my garage" '83 XJ550 last weekend from a 'friend of a friend' and got her running after it sat for at least 3 years.
    The following items from ebay are coming:
    Forks (surface rust has cut one seal and it is leaking a lot)
    Front brake pads (see 'Forks')
    Turn signal stubby things
    Left switch housing (horn and dim/high switch broken)
    Left and Right side covers
    Still need:
    Bleed front brake after new pads as it is ubber spongey and the brake light switch is not activating.
    To fix speedo, previous owner put a Drag Specialties on it. No idea where to start trouble shooting this.
    Replace gas cap and side lock as these are currently being opened with a screw driver. Wold like them all keyed the same.
    Investigate valve clearance checking procedure.
    This isn't my first, or my only, bike so none of this scares me but I know that taping into the experiences from all of you will be a huge help! Hopefully I can return the favor.
    (edited subject line: added details)
  2. andrewlong
    andrewlong Member
    Cumming, GA
    Re: First post
    Welcome to the forum!
    Pics pics pics :D
  3. Orange-n-Black
    Memphis Area
    Re: First post
    Welcome and check those rear brakes.
  4. cooleo
    cooleo New Member
    Re: First post
    Thanks O&B! I found your thread about this...must admit I am surprised! As the back brakes are the only thing working reliably right now I will be replacing the shoes before she rolls again.
    Thanks again!
