Gets up to operating temp and dies
Discussion in 'XJ Technical Chat' started by amfmtxca, Sep 29, 2010.
  1. amfmtxca
    amfmtxca Member
    God's Country Lubbock Texas
    I went for a short ride and a not so short push back home. I let the bike run for a short time before I went for a ride, when it got to full operating temp it died and did not want to start back up. Can I get some ideas of what to check. I do pretty good at R&R parts but stink at troubleshooting. Thanks for all the help
  2. mlew
    Ignition pick-ups or colis are failing. Run the bike in the driveway and when it quits attack it with a meter to see which part is going bad. Take some readings beforehand with it cold to compare to readings when hot.
  3. amfmtxca
    amfmtxca Member
    I forgot this tidbit of info 1982 XJ 750 Maxim
    Thank You I do appericate the info and the quick response. I will get on that this weekend Thanks again
  4. RickCoMatic
    You need too determine if its Fuel or Ignition related.
    I'd have a look at the Alternator Brushes. Easy to do. 10mm limit.
    If you haven't done so, ... replace the Fuse Panel.
    See if you have Spark when the bike stalls.
    Clean the Kill Switch.
    Break the Battery down; see what the Cranking Amps are.
    Try running the Bike on Prime.
    (Or Reserve)
    Does the whole Bike go dead or it just won't start?
  5. dinoracer
    dinoracer Member
    Chattanooga, TN
    I will second that its most likely the pick up coils on the left side of the crank. Replace those with a known good set and you should be set to go. To check if its fuel related, when it dies unplug a spark plug cap from spark plug. With spare spark plug rest it against the head. DO NOT HOLD IT THERE, you might have a shocking time. If you get a white spark then its most likely fuel related, if you get a weak or no spark then it's ignition related. But like I said, its most likely the pick up coils.
    Sean
  6. bigfitz52
    We have no symptoms except "won't start."
    Could be electrical.
    Could be fuel.
    Could be a few dead tight valves.
    Could even be as simple as a plugged gas cap vent.
    We need to know more about the patient to make a good diagnosis...
    How many miles on the bike? Mods? (Pod filters, aftermarket exhaust, etc?)
  7. jeffcoslacker
    jeffcoslacker Member
    SW MO
    My 2 cents.
    Make sure it doesn't have a fuel line that gets soft as soon as it warms up and folds at a bend...
    I bought a bike once that did that...PO had put freaking clear vinyl tubing on for fuel line! Duh.
  8. RickCoMatic
    How do you come to the decision that the Pick-up Coils are to blame?
    Those Pick-ups are the simplest of parts on the Bike.
    Magnetic Pick-up's. They rarely ever go bad.'
    I'd blame the TCI before suggesting to swap Pickup Coils.
    With the information we have about this bike suddenly coming to a halt without being able to do any hand-on testing, we don't really know what it is.
    We just give the most likely problems to check.
    I'd place the Pickups on a list to be checked, sure.
    But, you usually find the Pickups working fine.
    They have the factor of simplicity working in their favor.
  9. jeffcoslacker
    SW MO
    Probably because of the description....in cars, the crankshaft position sensor (which is a glorified term for mag pickup coil) is known to act this way on a lotta cars...the windings around the mag that sense the field develop a small break that only opens the winding when the motor comes to full temp, and then it stalls and won't start again until cooling off.
    I have to admit it came to mind, but I'd like to know some more about the issue first too...
  10. amfmtxca
    amfmtxca Member
    Thanks for all the good ideas to check. ok first it has 30,000 + miles and all stock. the first 4 - 450 miles it ran great the last 25 - 50 miles is when this problem of running like it had run out of gas started I know the tank was nearly full the first time it happened, we sat for a few minutes it started up so we finished the ride to where we were going. on the way home no problems. begining of the ride it was 90 plus on the way home it was about 80 so I thought it was a vapor lock. then a few weekends ago I went about 5 miles it ran great, on the way home about 1.5 miles it quit running let it sit a few minutes got about a mile it quit again this time no matter how long I waited it would not start so I pushed it home. The best way I can describe it is like it's running out of gas. this last time it happened I had replaced the fuel petcock and put in about 2 gallons and it died after about 2 miles so I know I have gas I will check all of y'alls recomenditiions this weekend when I have some time. the fuse block is on my list of parts to buy, and going through all elec connections will be taken apart looked at cleaned where needed (proably all will be cleaned) and dielectric grease applied Thanks again for all your help
  11. RickCoMatic
    30,000 Miles, ...
    Alternator Brushes.
    Your Battery recovers enough to get you going.
    The Charging System can't keep up because the Brushes are too short.
    The Battery does not get charged.
    You "Live" off the Battery until you run-out of Amps.
    Then, you die.
  12. amfmtxca
    amfmtxca Member
    Ok thanks Rick I will check that also the PO said he put a new battery on it so I did not even think about brushes or the battery being a problem Thanks again
  13. bigfitz52
    First lesson: NEVER BELIEVE ANYTHING THE PO told you (unless you're related and then still be suspicious.)
    Next: Do you have first hand knowledge or any hard evidence the valves have ever BEEN TOUCHED? Not the PO's word, knowledge or receipts?
    Rick is right, at 30K the alternator brushes are probably mere nubs of their former selves.
    You can't just latch onto a bike that old and start riding it; things are gonna go very bad for you. Sure, it lasted for a while but the neglected maintenance is GOING to catch up and it sounds like it has started to.
    Read this: http://xjbikes.com/Forums/viewtopic/t=24010.html
    And know this: 30K is the mileage at which a completely neglected XJ will start to experience multiple failures; if the valves haven't been touched; the alternator never attended to; the brake fluid/lines/seals never replaced--- it's going to start "having problems."
    They're not "problems" and they're not your fault-- you have a quarter century worth of neglect to reverse.
    Have at it; you sound like you have the aptitude. There IS a learning curve; but it's fun once you GET A MANUAL and dive in.
    Welcome aboard. We've been there.
    Now go check those rear brakes before you ride another mile. http://xjbikes.com/Forums/viewtopic/t=15874.html
  14. amfmtxca
    amfmtxca Member
    Thanks I realy like this forum all of you all are very helpful. I have a long list of things to order, some I already have the head bearing conversion kit, to fix that annoying catch, master cylinder rebuild kit, caliper rebuild kits, brake lines (SS) fuel petcock these i have purchased Len has been great. I have 3-4 more parts orders rear brakes are in there and next summer should be problem free, or at least minor stuff. I don't like payments of any kind so a new bike is out of the question and I do like wrenching and it has been awhile since I been riding and yeah I am going through that learning curve again this is the newest bike I have owned. Thanks again
  15. bigfitz52
    Dude check my sig. I still ride the Norton.
    New bikes have too much plastic and are bloody uncomfortable, truth be told.
    Sounds like you're on the right track. It's worth it.
  16. RickCoMatic
    Here's the List:
    Engine Oil / Filter
    Final Drive Oil
    Air Filter
    Brakes (Complete / Especially REAR)
    Clutch Adjustment
    Brake and Shift Pedal Pivots / Lube
    Center & Side Stand / Lube
    Swing-arm / Lube
    Front Forks / Fork Oil
    Steering Bearings / Pack or replace.
    Wheel Bearings
    Battery
    Brake & Clutch Pivots / Lube
    Alternator Brushes / New
    Valves / Check
    Fuse Panel / Replace
    Fork Springs / New
  17. bigfitz52
    Rick, oh master of all things carburetor, you left CARBS off the list!
    Carburetors cleaned/ bench sync/ float levels checked/ vacuum sync.
    Careful inspection of fuel and vacuum lines for cracks/ splits.
    Inspect intake manifolds to ensure the cracks you almost certainly have do not go all the way through.
  18. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    the cam sensor does the job of the old style mag pickup on cars. all the crank sensor does is tells the computer it's on top dead center. so that the computer can keep the signals from the cam sensor in check.
    course, they both pretty much work the same. so i guess in reality you could call them both pickups. one just works more then the other.
    but like rick says. they're built with simplicity. on and off switchs that either work or they don't.
    the only cars i experienced that run cold and quit when warm. were bad fuel pumps. OR, in the case of fords. bad ignition control modules mounted on the side of the distributor. EEC IV module was notorious for that problem.
    i never had the fortunate circumstance of running into a bad crank or cam sensor. but i'm not saying that it don't happen.
  19. jeffcoslacker
    SW MO
    Don't wanna get into a pissing match over car repair, this isn't the place...but I have 30 years of shop experience, so it's hard for me to resist. Your description of crank+cam trigger is a pretty recent design, relatively. So I understand where you get that, yes cam trigger signal will suffice if the CKP fails while running on NEWER cars....I replaced a TON of failed CKPs that caused the heat soak stall condition on older GM, Ford, etc...back when it was the sole source of timing signal for injectors and ignition.
    Old GM's used to lose their bead on #1 TDC because of this and sneeze sometimes when you tried to start them and have long cranking times, until the ECM found TDC again...
    Come to think of it, the old Hall Effect sensor in the dizzy on early 80's Chrysler was known for this kinda stuff too....looked very similar to the unit on these bikes.
  20. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    amfmtxca,
    Have you found any thing yet?
    MN
  21. amfmtxca
    amfmtxca Member
    hey guys so far I found the alt brushes are about 1/2" long, don't know if that is long enough or not, and there is no spark, battery cranking strong, but a littlle low so I added distiled water it shows 11.73 on my meter Thanks for the help
  22. amfmtxca
    amfmtxca Member
    looks like I will be buying new coils the factory manual says the primary ohm reading should be 2.5 + or - 10% mine are 2.6 each secondaries are suppose to be 11k + or - 20% mine 29.76 & 22.32 the alt brushes are approximately 1/2 Thanks for all the help
  23. snowwy66
    snowwy66 Member
    if you take the caps off. the coils through the wires should show 11k. the caps are 5k each making an addition 10k. so if you measure at the caps. you've got 21k. within specs.
    i'd be more concerned with the battery measuring 11.73. (if i read your post right) you might have enough to crank but not very fast and it's probably not enough to produce spark along with that crank. you could probably push start the bike. but not crank start.
    with the plugs pulled out. you might get a spark.
    a fully charged battery is considered 12.6.
    3/4 charged is considered 12.45
    1/2 charged is considered 12.30
    1/4 charge is considered 12.15
    12.0 volts and your considered dead. you might be able to crank. but odds are slim for a spark.
    anyone been able to crank and still have spark under 12v????
  24. jeffcoslacker
    SW MO
    Nope...
  25. bigfitz52
    You definitely want to fully charge the battery and have it load tested at the auto parts store.
    Alternator brushes have a "wear limit" line cut into their sides; if the line is gone they are past the limit.
    These bikes can exhibit the phenomenon of spinning the motor quite vigorously but not producing spark-- this is the sign of a soggy battery.
    Might also want to check the valves if you haven't yet...
  26. Robert
    The US models used 5k caps on the outboard wires (1-4) and 10k caps on the inboard wires (2-3). This assumes the original caps are in place. Most folks get the 5k caps to replace any that fail so measure your caps to be sure. I just measured a set of inboard wires this evening with another forum member and read 11k across the secondary high tension leads. I understand that the explaination provided in the book is rather confusing but you should see, through the caps, 21k for coil 1-4 and 31k through 2-3.
    Amen brother, testify!
    [quote="snowwy66]"anyone been able to crank and still have spark under 12v????[/quote]
    Nope!
  27. snowwy66
    snowwy66 Member
    i was just thinking about that. that 2 and 3 measured higher. totally forgot about those 2 caps being 10k. shorter distance to travel then 1 and 4.
  28. bigfitz52
    Nope![/quote]
    Ahem.
    BATTERY.
    Either it's time for a new one or it's not being fully recharged by the bike or both. 11.73 volts ain't gonna fire an XJ, pure and simple.
    You're gonna spend a whole lot of time (and money) chasing after all these relatively obscure deviations from specification when the obvious answer is right there. Further, if you don't deal with the battery, all the fussing over plug wire resistance and other minutiae, while being all well and good to attend to, will not fix your problem.
    also...
    I haven't seen a response yet as to when the valves were last checked...
  29. amfmtxca
    amfmtxca Member
    Good Morning just got home from Church I have not been out to the bike yet answer to when valves last checked I have not checked them. I put a triclke charge on the battery over night will check that first as soon as I get out there. I do not remember seeing a limit mark so I will check that again, proably should just get new ones they are not that much save having to do it later
    Thanks for the wealth of knowledge and willingness to share it
    I will get back in a bit with the findings
  30. amfmtxca
    amfmtxca Member
    I found thw battery after 11 hour trickle charge the multimeter reads 11.78 so I will get a new battery and start again
  31. snowwy66
    snowwy66 Member
    you can buy them at any auto parts stores. walmart too. autozone sold me one for suzi for $42.
  32. amfmtxca
    amfmtxca Member
    Alright Thanks for that info I will go to Wally World (WalMart) & get a new battery
  33. amfmtxca
    amfmtxca Member
    Turns out the battery was the problem. the battery reads 12.5vnot running it reads 13.53v running I will still order the brushes. tomorrow I will take it out for a test ride Thanks for all the help this site is the best
  34. snowwy66
    snowwy66 Member
    13.53 is good volts. it should go up to at least 14v when the throttle is revved a little. but your charging. that's the main thing.
  35. amfmtxca
    amfmtxca Member
    I took it out today put on about 30 miles, no problems I shut it off check the meter reading the battery was at 12.95 so Thanks again for all the help and all the things to check I appericate it
  36. bigfitz52
    That's good news. Watch the water level and monitor your state of charge after the next few rides.
    Did you say the alternator brushes had no "wear out limit" line left?
    Might want to go ahead and get them changed, based on your miles. Book says 10K, I think they just want to make you look at them. Mine on my '81 (550) still had lots of meat left past the lines at 18K, I'll be checking them again soon since I'm at 27K now. I'm betting I'll be replacing them around 30K miles...
    Now about those valves... http://xjbikes.com/Forums/viewtopic/t=14827.html
  37. amfmtxca
    amfmtxca Member
    Thanks bigfitz52 i did not notice any lines on the brushes so they are on the list to replace, and so are the new gaskets and doughnuts and the tool for adjusting the valves, I think I have mm feeler gauges, I have a 63 VW bug that forced me to start picking up mm tools shortly after getting the VW. This winter lots will be done, for now short rides till next time Thanks for everything
