DIY front controls WITHOUT a welder realistic?
Discussion in 'Hangout Lounge' started by Metal_Bob, Oct 7, 2010.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    I can't search so great with my phone so...
    How realistic or NOT to make front controls for 82 750 maxim without access to a welder?
    I mostly have hand tools, dremel and bench grinder.
    I'm sure with TIME and my engineering degree I could figure something out... but i'm not sure if I'll NEED welded parts.
    I ask because my first test ride WITH the wife had my legs cramped (sitting more foward) and harder to shift & brake. I'm 6' and neither of us are lightweights...
  2. iwingameover
    iwingameover Active Member
    It's possible. The only real obstical to overcome would be the linkage. I made mine with almost no welding. I only welded the tube adapters to the end of the links and some angle to the plate for my pegs.
    Pegs could easily bolt on if you're using some of that variety.
    Honestly, just order a set from TC bros or something. By the time you get materials and a design hammered out it'll be easier and almost as cheap.
  3. Metal_Bob
    Bourbonnais, IL
    Not exactly cheap but seen them on Ebay. Food for thought I guess
    Edit
    Those Tc controls do look nice. However moved controls will make it even harder for my 5' wife to mount up. Lol
  4. iwingameover
    I thought they were too much too. Then I spent around $100 in materials for mine plus my time. Would have been quicker and less of a headache to just bolt the others on but a bit more $$.
  5. Metal_Bob
    Bourbonnais, IL
    Good points
    Maybe after I get a job and/or she rides alot I will just buy them.
  6. iwingameover
    Forwards are sweet. With those and my tractor seat I'm comfortable for a full tank easy. If I had a little windshield that would be better still. I'm 6'4.
  7. Jay~Dub
    Jay~Dub Member
    (not so) sunny North Wales, United Kingdom.
    BOB!! don't let anyone put you off, Use your skills and make your own - take up the challenge, some people just don't understand the satisfaction you would gain, "one off" means something. use what you have worked so hard for to make something your way, invent. were theres a will... :D
  8. iwingameover
    Just saw your edit. I also left my stock pegs. Sometimes I move my feet back to bend the knees a bit.
    JayDub I wasn't telling him not to I offered an option based on my experience.
  9. Cmccully04
    Cmccully04 Member
    State College, PA
    Go for it, I only used my welder a couple times, im sure you could do it, or maybe make a post on CL and ask for someone local to do a couple welds for ya for a case of beer or what not. They're pretty simple, I did my own as well, and with material I have less than $30 bucks in them.
  10. Jay~Dub
    Jay~Dub Member
    Respect to you fella, I wasn't having a go at you in particular! It just seemed like he was giving up slightly... Just wanted to give Bob a bit of encouragement. He may regret not trying. :)
