Air Shocks
Discussion in 'XJ Technical Chat' started by Sodacubes, Nov 10, 2010.
  1. Sodacubes
    Sodacubes Member
    Pottsville, PA
    Well here is the pictures of my newly aquired air shocks that i got at the junk yard today off a 81 maxim 1100 fully dressed, sad to see it in that condition however i managed to salvage some parts for reuse, These air shocks that will go in my 550 so me and my girl can ride more comfortably, and a in better shape then my origanal master cylinder and caliper all for $20 , that makes me happy. The boots says KYB so iam guessing thats what they are :D
    Only real reason i am adding the air shocks is because me and my girl are not all that small, we like to eat good lol. Notice the Yamaha Speakers LOL.
  2. Robert
    Looks like the boots are missing, good luck with those shocks. I picked up a set years ago, got them home and they were blown (oil dribbling out of the air line). I've yet to find anyone who will rebuild them.
  3. Sodacubes
    Sodacubes Member
    Pottsville, PA
    I got the boots lol, there is one sitting there on the table in the pic. No leaks, holds air fine. $10 cant say no .
  4. Robert
    Ah, wow to me and my failing eyesight. I don't remember my boots having convolutions on them. Hey, if they work, they work. You done good bud, go enjoy them.
  5. waldo
    waldo Member
    San Jose, Ca. 95125
    I dont know if you noticed yet but there is one huge problem with those shocks.
  6. Sodacubes
    Sodacubes Member
    Pottsville, PA
    What would that be? besides dirty, they hold pressure and dont leak.
  7. waldo
    waldo Member
    San Jose, Ca. 95125
    They are not on my desk in front of my speakers fixing to go on my bike Man you got a great deal.
  8. Sodacubes
    Sodacubes Member
    Pottsville, PA
    Only thing i noticed is the left side bottom mount hole is smaller then the right side.
  9. Sodacubes
    Sodacubes Member
    Pottsville, PA
    Ahhh haha had me worried for a min.
  10. Saber
    Saber Member
    Reading, PA
    Here you go Robert, a guide on How to do it yourself.
    How to rebuild your XJ1100 shocks!
  11. Saber
    Saber Member
    Reading, PA
    I have a set of these shocks sitting in a box waiting to go on the bike. The only thing I am wondering is how I will route the air hose over the tire.
  12. TIMEtoRIDE
    The shaft drive bikes have two different lower hole sizes, apparently on the 1100 also.
    I'm running the Turbo 650 shocks on my Seca 900 with no ill effects.
    Ten dollars is a deal on almost any XJ part that you need, let alone the working shocks !!
  13. Sodacubes
    Sodacubes Member
    Pottsville, PA
    Re: Air Shocks Test FIT
    Ok i test fitted the shocks today, they fit fine, only issue is the boots touch the pipes and i am sure they will melt.
  14. Robert
    EXCELLENT! I saved the entire page on a OO presentation. Learned that my shocks are MISSING the boots! We'll see what I can cobble together.
    Thanks a bunch!
  15. bigfitz52
    Not as much as you might think but yes. Easily solved: remove the mufflers and carefully bend the mounting tabs outward about ten degrees or so; when you remount them it should swing the muffler out about 3/8" or so and give you some clearance.
    But enough of that.
    We need to discuss YOUR CHAIN. OMG.
    Start a new thread "what's wrong here?" and post that picture of your drive chain and rear sprocket. Jeezus, dude. Seriously.
    Oh, and did you find a spacer bushing for the oversized mounting hole? I have a whole drawer full of shock absorber mounting bushings, if it's flopping on a smaller diameter bolt PM me with ID and OD and I'll see what I have.
    After we talk about that chain.
  16. Sodacubes
    Sodacubes Member
    Pottsville, PA
    well the bike sat 4 years never ridden so it is going to look rough, one thing at a time.
