carberator throttle mount and choke mounts needed!!!
Discussion in 'For Sale, Trade/Swap, Wanted' started by ford_fan, Nov 19, 2010.
  1. ford_fan
    ford_fan New Member
    I am in need of both the throttle cable mount the choke cable for the carbs. Iv looked and this part can't be bought new so I'm hoping somebody has a pair laying around or on a spare set of carbs. Pm me if u got a set ur willing too sell
  2. SovereignDragon
    SovereignDragon Member
    Leavenworth, KS
    Ok, i definitely have what you need but am a little confused. Can you explain them just a little better?
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    maybe post a picture of what you need may help.
    MN
  4. ford_fan
    ford_fan New Member
    Its the metal tabs that bolt to the top of the carbs that holds the throttle cable... there is a 2nd mount that holds the choke cable... ill see if I can find a picture
  5. bigfitz52
    Oh, I think we pretty much know what you're talking about.
    What we DON'T know however, is WHAT BIKE you're talking about.
    Those bits are different from XJ to XJ.
    These would be for a 550:
  6. SovereignDragon
    Leavenworth, KS
    All my carb parts I have are from a 1980 XJ650. How about I take a picture of what I think you are talking about and we can go from there?
  7. ford_fan
    ford_fan New Member
    I am needing them for an 82 xj650 sorry I forgot that bit of important information guys
  8. ford_fan
    ford_fan New Member
    Ok I have the cold weather cable mount I just need the throttle cable mount and the two screws that hold it on. Its for an 82 650. Message me if you have one! I will buy it
  9. bigfitz52
    XJ650 what? Seca/Max?
    It's usually mounted using two of the carb hat screws.
  10. ford_fan
    ford_fan New Member
    Its a maxim yes it has two screw the go into the hat ontop of the carbs. Those two screws r missing as well as the mount.
