Had to push start
Discussion in 'XJ Technical Chat' started by vanillaice, Nov 24, 2010.
  1. vanillaice
    vanillaice Member
    You can read my other posts for background, but here's the basics.
    Friend gave me '85 XJ700 Maxim in Colorado that had been sitting in a shed for two years. Dropped in a new batt and some gas and it fired up after a lot of tries. Shipped it to FL. Rode it around a bit and it idled at about 4k. I figured that was b/c of the dirty carbs or maybe some dirty gas in the lines.
    Then it just died one day. One click from the solenoid and nothing except electrics. I put some blaster down the plug holes and rocked it in 5th gear and could get it to start sometimes, but mostly just one click on the solenoid and nothing but electrics turning on.
    Someone on the forum recommended cleaning the starter. Cleaned a ton of black crap out of it and the bike came to life instantly. Didn't really idle high anymore that much either.
    I knew the carbs were dirty, and want to get around to cleaning them, but, Hey, I have a running bike in my garage and it was too tempting. I decided it was time to ride and put about 30 miles on it.
    Then, as I was getting ready to leave work, it did its same old thing again. One click on the solenoid, lights are on, but it won't even attempt to turn over. Just a click from under the seat. I was so bummed.
    I was able to push start it and it turned over on the second attempt, but was sputtering and backfiring a little bit. I rode it 20 miles home and it rode ok, but idled at about 4k at stop lights. I parked it and tried to turn it on again and it did start up, but now I don't trust it anymore for long rides away from home.
    I know I need to clean the carbs, but am busy and can't do it until the middle of next month.
    Any ideas on what happened? Is it just the carbs or why would it start and run fine for a couple days and about 30 miles of riding and then not start unless it is push started?
    Thanks for any ideas.
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I would start by checking battery voltage when it won't crank over. If ok, Then I would check every electrical connection and grounds to make sure that you are getting full power from the battery to the starter. Its weird it runs ok one time and then crappy the next time.
  3. Polock
    ya have to make the distinction between, won't start, as in "cranks but no go" or "clicks is all i get" or "kaput dead"
  4. vanillaice
    vanillaice Member
    One click is all I got when I pushed the starter button.
    But then I pushed it, popped the clutch and it turned over and started.
  5. vanillaice
    vanillaice Member
    MN-Maxims,
    What's the proper voltage it should be putting out?
    Also, do I only check the relevant electrical connections like batt, starter relay, etc or all of them?
  6. MN-Maxims
    Saint Paul, MN
    If your battery is fully charged it should read over 12.6 volts But I am more interested to know what the voltage drops to when you hit the start button.
  7. Polock
    since you just fixed the starter, if you only get a click and the starter doesn't go, the starter solenoid is going south
    for a test you can cross the big terminals on it with a screwdriver but make sure it's in neutral
  8. vanillaice
    vanillaice Member
    Ok. That makes sense. So, if it stays close to 12 volts, there isn't a short or ground out somewhere?
  9. vanillaice
    vanillaice Member
    Polock,
    I tried that before and it sparked, but didn't turn over when I crossed the terminals with a screwdriver. If I remember right, crossing the terminals with a screwdriver should spin the starter motor, right? If not, there is something wrong with the solenoid?
  10. Polock
    right?, right
    not the solenoid, the starter
    when you cross the solenoid you hook the battery right to the starter, even if the key is off the starter should spin
  11. apsolus
    apsolus Member
    dahlonega ga
    yeah cleaning a starter isnt gonna fix it forever, next get a rebuild kit online and rebuild it. then you can look for your idle problem. you gotta fix the obviouse before you can fix the little things. while you wainting on parts remove the carbs and clean them up really good and check out the faq suggestoins page on the forum for tips on syncing and rick-o-matic had a brilliant page on the needle slides. and someone else had a post on a really easy way to bench sync the carbs. my bike was reving to 5 grand till i fixed the sync now it runs great. good luck my boy
  12. vanillaice
    vanillaice Member
    Since I am trying to learn all I can on this, I am now curious--What does rebuilding the starter do that cleaning it doesn't? I was looking at rebuild kits which run about $30 and they look like just some of the basic parts and gaskets. What does a starter rebuild kit do exactly?
  13. vanillaice
    vanillaice Member
    P.S. She is now back to starting up fine!
  14. apsolus
    apsolus Member
    dahlonega ga
    the rebuild kit replaces the parts that wear out over time.
  15. PaintIt(Flat)Black
    PaintIt(Flat)Black Member
    Sterling, MA
    Rebuild kit replaces the Brushes, but what else?
  16. 82XJTurbo
    82XJTurbo Member
    South Texas
    There's a wee bit 'o difference in altitude between CO and FL. May want to check the jetting in the carbs too.
  17. waldo
    waldo Member
    San Jose, Ca. 95125
    bearings bushings seals brush holder depends on the brand of kit you buy
