Seca forks
Discussion in 'XJ Modifications' started by RECAC, Dec 21, 2010.
  1. RECAC
    RECAC New Member
    NE Ohio
    I have a 82 XJ650RJ, with a mysterious past, that is in the process of being resurrected. The forks don't appear to be original to this bike. While the lower legs appear to be identical to other 650 Secas, the stanchion are one inch longer. Anyone know what bike these forks might be from?
  2. Cooter
    Cooter Member
    Chi-Caw-Go
    Lots of possibilities without pix. Could you maybe post a couple so we know what we're dealing with?
  3. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Maxim?
  4. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Does the front axel bolt up to the front, middle, or rear of the leg?
  5. Thrasher
    Thrasher Member
    He may have original lowers with Maxim tubes.
  6. RECAC
    RECAC New Member
    NE Ohio
    Problem solved: I think. On disassembly, I found a preload spacer that was much larger than one would expect. It was making so much preload that it was compressing the rebound spring thus making the overall length greater.
